Small 120 volt breaker alternative? - Fiberglass RV
Old 09-29-2013, 06:47 AM   #1
With freezing temperatures here I want to get 120 put in the Boler so we can use it in the winter to get away (electric heater). The beaker boxes are large, has anyone found a really small option, or any ways of doing this that I should look at?
Any and all ideas appreciated
Nelmes is offline   Reply With Quote
Old 09-29-2013, 07:02 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
My UHaul came with just a standard double width electrical box. One one side is a GFCI outlet and on the other side is a simple thermal breaker like this one:
Old 09-29-2013, 07:07 AM   #3
GMike A's Avatar
I am not trying to be facetious but if you dont want to go whole hog then something as simple as this would get you by at little expense and installation for now. then you can decide what you want to do next summer. Just a thought.
Mike
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 09-29-2013, 07:10 AM   #4
Thomas G.'s Avatar
Mike
I think your photo is of a GFCI protected cord. Here is another with a circuit breaker:
http://www.lowes.com/pd_145271-33536-C664502001_0__
Old 09-29-2013, 08:32 AM   #5
GMike A's Avatar
Yep you are right Tom. I was looking at another one but saw it was an import and it had a CB in it but snagged another picture instead during my surfing. Good Catch and still shows that you can get away for less then $15 bucks or so and do the job. Would work great for that electric free standing heater, toaster or whatever without any major mods.
Mike
Mike
K5NAN
"Miss Adventures"
Old 09-29-2013, 08:56 AM   #6
Ed Harris's Avatar
You can get a simple box that will hold a single or 2 breakers for under $20.00,way under I think?
Then just stick a few breakers it there and call it a day.
It does not need to be a big breaker panel but just a small disconnect sized box will work fine.
GE PowerMark Gold 40 Amp 2-Space 4-Circuit Indoor Main Lug Load Center-TL240SCUP at The Home Depot
Just one example.
Ed Harris is online now   Reply With Quote
Old 09-29-2013, 09:24 AM   #7
Thomas G.'s Avatar
.......Would work great for that electric free standing heater, toaster or whatever without any major mods.
Mike
Yep, you are right.
Two 6 volt vs. 12 volt deep cycle Kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
Can you plug into 120 while the 12v batteries are out? Cam A Care and Feeding of Molded Fiberglass Trailers 8 06-30-2010 09:25 PM
120 volt wire connectors Carl G Problem Solving | Owners Helping Owners 7 05-28-2010 10:45 AM
Problems with Refrigerator on 120 volts John Blair Problem Solving | Owners Helping Owners 14 05-07-2007 02:55 PM
