Small bad spot in my Burro floor - Fiberglass RV
Old 06-30-2013, 08:14 PM   #1
Trailer: 81 Burro
Hi everyone.
I just bought a 1981 13ft burro. It was well kept and in good condition with a couple modifications done by PO. I wanted to strip the inside and redo it with my own Ideas and in doing so I noticed the body on the front passenger side was crushing slightly on the frame. No cracks in the frame are evident, but when I looked in the front, right-side compartment, there is what feels like a rotted patch of floor. You can see in the pics,( I hope they uploaded) the "ring" of saturated wood that is rotten near the front of the body. What are my options for repair?
Thomas A
Thomas A is offline   Reply With Quote
Old 06-30-2013, 08:28 PM   #2
Hi Thomas, to FiberglassRV, we're glad you're here
There are lots of kind and helpful people on the forums, I'm sure one will be along shortly with an answer to your question.
BTW: I'm not seeing any picture
Old 06-30-2013, 09:00 PM   #3
Could you get a piece of steel plate under the floor between it and the frame and big enough to bolt through solid floor area to eliminate the body sag. Then cut out the bad spot and put in a new section. I'm not familiar with the burro frame, but could you also add another frame member for better support. Another Burro owner will most likely have some better ideas.
Old 06-30-2013, 10:14 PM   #4
Trailer: 81 Burro
http://www.fiberglassrv.com/forums/a...1&d=1372651162
ID:	61366my burro floor pics,,,I hope
Old 07-01-2013, 04:27 AM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Google "GitRot".
Old 07-01-2013, 06:55 AM   #6
Trailer: 1980 Burro
Originally Posted by Thomas A View Post
Hi everyone.
Thomas A
Thomas,
Good luck with your floor repair. I replaced the entire floor in my 1980 Burro. Before I ripped up the floor I did not think that there was nearly as much rot as I found.
If you have not already seen it, take a look at the following link.
No wonder the Burro floor is rotted
Andy
Andy B is offline   Reply With Quote
Old 07-01-2013, 07:49 AM   #7
GMike A's Avatar
Also as everyone will say. Find the source of the leak(s). Otherwise you will have wasted your time.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-01-2013, 06:33 PM   #8
GitRot may fix the soft floor, but it's not going to lift that corner of the body off the frame... as you know. I'd lift it first so you can check all of it. You don't need to remove the body from the frame, just loosen the bolts and lift it a bit...
Old 07-01-2013, 09:48 PM   #9
Trailer: 81 Burro
Burro Floor
Great advice from everyone, thanks. I looked the spot over after Donna suggested looking under the frame, and inside, where the floor meets the curve of the wall, the fiberglass is cracked just where that saturation ring of rot is in the photo. I think that's why the corner of the body is sagging and dinging on the frame.
burro
rotten burro floor HELP?!!!??? kygould Problem Solving | Owners Helping Owners 4 07-08-2011 12:35 PM
13' Burro Floor Scott B. Modifications, Alterations and Updates 15 08-03-2009 09:11 AM
The Burro and the bad tranny Myron Leski General Chat 31 08-24-2006 11:46 AM
New floor for Burro Myron Leski Modifications, Alterations and Updates 14 05-14-2006 04:29 PM
13' Burro Floor Mark Hutton General Chat 0 12-31-1969 07:00 PM
