Small Hehr Crank Window Screen - Fiberglass RV
Old 03-25-2015, 06:29 AM   #1
Trailer: 82' Scamp 13
We have the small crank window over the stove in our 82 scamp that needs a window screen. Does anyone know or have a photo of the screen and how it goes into that window? I've redone the other two crank window screens in the camper but this window didn't have one and seems a bit different.
I found the glass gasket at vintage trailer supply. But no screen parts that I saw.
Name:	ImageUploadedByFiberglass RV1427286286.007474.jpg
Thanks!
Sent from my phone using Fiberglass RV
Cmtravels is offline   Reply With Quote
Old 03-25-2015, 06:55 AM   #2
Ian G.'s Avatar
The small window screens are installed the same way as your other windows except there is no seperate frame for the screen. The screen is mounted directly into the window frame. There should be a rubber bead that is interted into a groove in the frame, the sceen is placed over the window, overlapping the groove and the rubbber lockstrip (with the screen under it is then pushed into the groove, that holds the sceen in place.
When I rebuilt these windows on my Boler rather than replace the glass gasket I placed a bead of butyl tape around the inside of the window frame then installed the glass into the bead, this seal is working very well and should last a lifetime.
Old 03-25-2015, 07:10 AM   #3
Thanks for the quick reply!
So you would remove the crank and then use the normal screen spline (?)
Name:	ImageUploadedByFiberglass RV1427288943.806345.jpg
Old 03-25-2015, 07:11 AM   #4
Here's another shot of what the channel looks like.
Name:	ImageUploadedByFiberglass RV1427289098.553746.jpg
Old 03-25-2015, 07:18 AM   #5
Ian G.'s Avatar
Exactly. I would recommend you get new spline, the old is probably hard and won't hold well. You can buy new spline at any Home Improvement store, just get the correct diameter.
Old 03-25-2015, 07:22 AM   #6
Great! Thanks so much. I tried it with what we had and it's too small to hold the screen in so I'll pick up a thicker one next trip!
Replacing Hehr Crank Out Window on Scamp 13 CampyTime Problem Solving | Owners Helping Owners 9 08-16-2014 07:19 AM
Joulsie Hehr crank out window needed for my 13' Scamp ncrrover Modifications, Alterations and Updates 5 06-04-2013 10:19 AM
SOLD - Small Crank Window Nakita B Classified Archives 2 06-16-2008 11:12 AM
Hehr window screen parts. DanPatWork Problem Solving | Owners Helping Owners 1 01-09-2008 04:37 AM
Crank'n'go solar/crank am/fm radio Legacy Posts General Chat 12 09-03-2006 11:12 AM
