Small table - Fiberglass RV
Old 11-25-2008, 10:27 PM   #1
Don N's Avatar
Trailer: 1997 Bigfoot 25B21RB
Had an idea that I wanted some feedback on. If we leave the table made up into a bed and would like to redo our front couch something like Doug did with his. My idea is to install a sunken support for the round table support as opposed to having one sitting up above the floor in front of the couch. Then when you are sitting at the front couch, you will have the use of a smaller removable table. It would have to be made in such a way that you can still have access to get out around it and not be interferring with anybody walking in the side door. If it is a sunken support, there is nothing to trip over when the table is taken down. Now I am presuming that the centre section of the floor is 3/4" plywood and I can cut out a hole in it and install the sunken support. Am I missing something here or will it work?
Thanks...
Don N is offline   Reply With Quote
Old 11-26-2008, 10:26 AM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
I could be wrong, but I think you are right on the money with what our plan is. Yes its plywood underbelly. Be doubly sure that there is/are no obstructions under where you plan to dig to plant your base. We had thought of doing this too and planned to bury the base right in front of that l'il indentation in the glass wall that forms the base of the seat. PLEASE let us/me know how this works for you.
P.S. Be SURE to chalk underneath the flange of the sunken table support, I'm wonderin IF a dab of some sort of sealant from the underside of the trailer might not be a bad idea either????
Old 11-26-2008, 11:38 AM   #3
Pictures, don't forget to take lots of pictures. Inquiring minds will want to know!
Old 11-26-2008, 01:19 PM   #4
james kent's Avatar
Trailer: Boler 1984
Just a little added information for whatever it's worth. I added a center mounted small table in our Boler last year. Yes the floor in ours is 3/4 " plywood covered with fiberglass on both sides, so our construction is similar to yours. I cut the hole with a hole saw attached to an 18 volt cordless drill and put some butyl tape around the edge before screwing the floor flange into place.
After a summer of use I have added a support bracked to connect it to the front of the trailer to a piece under the front window. We did this because we found the table just too wobbly no matter how we tried to keep it tight on the riser piece. Later I want it to connect with a rail similar to the way the big table did, because we can then take it down and place it back on the bench and still have a gaucho type bunk if we need it.
Old 11-26-2008, 01:27 PM   #5
james kent's Avatar
Trailer: Boler 1984
Here's the table before we connected it to the piece under the window. I want to change it to make it more stable, so make sure you give us lots of pictures.
Old 11-26-2008, 04:00 PM   #6
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I would also use stainless steel washers, Nyloc nuts and Bolts. and also know exactly where your propane lines are. might not be a bad idea to re-glass the edges of the hole (cover the raw wood) before you mount the post hole. drilling holes in my egg always makes me think way too hard, sorry
Scott S. is offline   Reply With Quote
Old 11-26-2008, 09:54 PM   #7
Don N's Avatar
Attachment 16949
James, I like your table but mine would be a lot smaller and will face opposite to yours. I want to leave the front couch in with no dinette. Will be sealed at the floor for sure.
Old 11-26-2008, 10:13 PM   #8
james kent's Avatar
Trailer: Boler 1984
We put a permanent bed at the other end. Check underneath. That,s where my water tank is located. Would be a beast if you accidentally put a screw through it. The table top will still fit in the bench and the piece of cushion is being used as a back rest so it too can still be placed to use use as a couch. Will look forward to your finished table.
Old 11-27-2008, 05:38 AM   #9
Don N's Avatar
Will definetly check underneath first. Fact, maybe measure and check underneath 12 - 15 times before we do the first cut Hope to get out to the local RV place in the next week or so and see if he might have a used table and stand that will fit our application..
Old 11-27-2008, 10:40 AM   #10
Doug Mager's Avatar
Don???
What do you think of this plan of attack for sinking that base???
Invert the base at the location where you finally decide to place it, trace the outline of it with a pencil, remove the base leaving a circle on the floor. Find the middle of the circle and take a drill and drill a pilot hole through the floor (after checking to be sure there's nothing right under where you want to bore that hole). Then, go back under the trailer and drill the hole out (would a hole saw work any better than a jig saw??) from underneath. If you need to use a jig saw, doing that hole from underneath would probably give you more manuvering room than using the same saw from inside the trailer ......just my 2 cents (Canadian, eh?)
OOPSIE: I negleced to remind you that the scribed hole will be LARGER than the hole you actually bore from underneath, so you'd need to account for this difference in size when drilling up from underneath!!!
Old 11-27-2008, 01:58 PM   #11
Raya's Avatar
What is the composition of the floor right there? Is there a wooden core in that area? I know that underneath it's gelcoated fiberglass, and inside it's fiberglass. I would assume there would be a core for stiffness - probably wood - but I wouldn't imagine it would be more than 1/2" to 3/8" thick.
Not that this means you cannot sink the base there, but something to think about.
I think if I were going to sink it there, and assuming the fiberglass+core is about 1" thick (you need more depth for the base, right?), I would probably laminate a solid fiberglass block to the underside of the trailer to take up the excess depth. You could also go with a resin-coated exterior or marine plywood piece (cheaper and somewhat easier), but the fiberglass would never rot. You can also tap the fiberglass for a machine screw which might come in handy (I don't have all the particulars here, such as the depth and layout of the fasteners on your base socket).
I like the idea of a table socket there; you could then have many of the advantages of the forward dinette while keeping the sofa/bunks.
Raya
Old 11-27-2008, 09:34 PM   #12
Don N's Avatar
Raya, I like the idea of the glassed in piece of wood underneath to increase the floor thickness. I will have to find a sunken base and get some details on the size, etc. Even thought of possibly putting two small single tables there instead of one wider table. They should be a little more stable but then you have two sunken holes in the floor. Guess you could cap them when not in use. If we think about it long enough, I imagine we could come up with another idea to use these sunken holes for as well.
Old 11-28-2008, 12:14 AM   #13
Trailer: 1976 Boler 13 ft
Thanks...
I went simple and just made a table the size of the middle sofa cushion support. I like versatility and did not want to lose the top bunk option. Now it can be a sofa, a bunk, or a dinette depending on the need at the time. It is small but still holds two place settings. it is not quite done though. i would still like to add the hardware to the table top so it swivels and glides into different positions. Some day...... I will see if i can add a picture, wish me luck. The drop leaf gets out of the way when needed as well.
cyndi H is offline   Reply With Quote
Old 11-28-2008, 07:03 AM   #14
Don N's Avatar
Thats kinda the idea I have Cindy but my trailer does not have a cut out at the middle cushion. It is one piece straight across so my mount will be out in the middle of the traffic area more. Thats why sunken. You mentioned a drop leaf, never thought of that. Might be able to work that into this plan.
How small is small? How about a bicycle/motorhome hybrid? John Mc General Chat 9 11-30-2012 06:42 PM
Looking for a web video of small model car towing a small model traile ronsmith100 General Chat 3 02-14-2009 08:02 PM
Small fan Ami P Problem Solving | Owners Helping Owners 13 07-31-2008 09:40 PM
small folding table in scamp Diane G Problem Solving | Owners Helping Owners 2 06-23-2008 04:31 AM
Small Table Mod Legacy Posts Modifications, Alterations and Updates 2 08-18-2003 08:16 PM
