Small wheels for Scamp garage parking??? - Page 2 - Fiberglass RV
Old 09-13-2015, 05:42 AM   #15
Originally Posted by Samwise View Post
Arne, is this an off-the-shelf item, or did you make it?
Harbor Freight, and most auto supply stores, have similar items:
Search results for: 'car dolly'
BUT... Personally, I wouldn't be too keen about resting the weight of the trailer on the brake drums. They weren't designed to be load carrying.
A while back there was a pic from a member that made plywood disks slightly larger than the brake drums and bolted those on with the wheel lug nuts to prevent pressure on the drums.
Old 09-13-2015, 07:11 AM   #16
Samwise's Avatar
Name: Bill & Pam
Trailer: 2016 Bigfoot 17.5
Bob, thanks for the link, I'm going to see if that will get my Scamp low enough to get it into the garage.
Samwise is offline   Reply With Quote
Old 09-16-2015, 03:43 PM   #17
Trailer: 1999 Casita 17' SD
Ohio
If your asking about the car dollies they are a standard item. Here's a pair at Harbor Freight.
Vehicle Dollies - 2 Piece, 1500 Lb. Capacity
Arne has put some 2x4's on them to keep the trailer on them.
Joe
Old 09-16-2015, 07:00 PM   #18
ArneB's Avatar
Trailer: Boler 1975
Email
Name:	ImageUploadedByFiberglass RV1442450888.571105.jpg
Sorry to respond late.
The dollies are custom. However Princess Auto sells very similar and are the same height off the floor. I found the hubs rotated in the dolly when moving the Boler. In the picture I placed a 2x4 in front and back of the hub to minimise rotation and to stabilise I placed a 2x4 under the bolts and in back. Bungee it to the dolly and its secure. I have about 3" clearance under a 7' door. I do not have a ceiling vent in yet.
This dolly setup sure makes it easy to manoeuvre the Boler in the garage. I use a hitch dolly to pull the Boler.
ArneB is online now   Reply With Quote
Changing out 13" wheels for 15" wheels Ed Morris Towing, Hitching, Axles and Running Gear 3 01-26-2018 04:14 PM
Steel wheels or fitting it in my garage?! PrettylilTrilly Problem Solving | Owners Helping Owners 14 07-11-2015 08:58 PM
how to move scamp into tight parking spot kayleigh0302 Towing, Hitching, Axles and Running Gear 7 08-18-2013 01:50 PM
Garage Storage, Dolly Wheels, What to do?? Surfside. AlbertaBound Problem Solving | Owners Helping Owners 5 09-29-2011 08:37 PM
fifth wheels for small trucks duffysjim General Chat 7 02-28-2006 03:27 PM
