05-05-2018, 12:13 PM
Smart Jack and Tailgate competition
Hello, Thanks everyone, for the great info and shared help always being provided for others in need. Anyway, just took delivery of our FG trailer and the only problem I have encountered, is the lack of space to bring my truck tail gate all the way down, when hitched up, due to the electric Smart Jack on the trailer. Seems I had seen a post where someone had rotated the jack sideways, maybe backwards? I've been searching several forums and cannot find information or suggestions on what to safely do, and I only need about an inch more of room. I hate to think that I have to unhitch each time I need to fully open the tail gate. Any suggestions or help from anyone who has had a similar experience would be appreciated. Thanks, again and again.
05-05-2018, 01:31 PM
member
Isle of Wight
Would this work? - You dont say what trailer..... Casita Jack Relocation Plate
Jim
05-05-2018, 01:40 PM
Arkansas
An extended stinger can also fix the problem. If the square tube on the stinger is long enough, you can just use the one you have, and drill a couple holes an inch or so further toward the end.
05-05-2018, 02:45 PM
Originally Posted by widgetwizard
Its a Bigfoot 25. Hoping to find a simpler fix, but will keep it in mind and research this. Thanks.
05-05-2018, 02:49 PM
This might work. I'll unload the trailer soon and look to see if the stinger ( had to look up that word) has a ready adjustment or choice of holes for the pin. I'll research the safety of drilling a new hole closer to the end. Thanks, rbryan.
05-05-2018, 04:10 PM
Arkansas
If it doesn't give you enough material to drill additional holes, extended mounts are available.
05-05-2018, 04:16 PM
Good to know, thanks. I will post the results of what I did, or might do. The trailer will be parked for a few months before I can actually get to it. But it will weigh heavily on my mind until it is actually done or I have a good idea of which direction to go. Thanks.
05-06-2018, 12:21 PM
Trailer: casita
extended trailer hitch
same problem w/casita and boat trailer
harbor freight has extender that works like a charm. Plug it into your receiver, plug the ball mount and you're done
10 minutes and $25 (more or less) and you're done
05-06-2018, 12:38 PM
Trailer: '15 17' LD Casita and '17 Tahoe LT
etrailer.com has longer receiver extensions for around $25. I bought a 12" for my last trailer from an rv dealer without shopping and paid $99. I let it go with the trailer when I sold it but I plan on getting another one for using with the Casita. I have a Tahoe and it also is about 2" short using the 9" extension.
05-06-2018, 02:07 PM
Thanks Gary, another option to ponder.
05-06-2018, 02:09 PM
Thanks for responding Dick, I will look into this possibility. All suggestions have been great.
05-06-2018, 02:27 PM
etrailer states that a hitch extender will reduce the capacity of the vehicle hitch by 50% (the leverage effect). With the heavy tongue weight of our Casita I would definitely not use one. I actually redrilled my ball mount so the ball is closer to the truck bumper. I installed an Ultimate Jack so that I can open the tailgate when connected to the trailer. I know the OP has a power jack so the Ultimate Jack is not a solution for him. I would relocate the power jack.
05-06-2018, 03:01 PM
It may, but I used it on my 25' Airstream with a weight dist. hitch for 6 years. Don't remember what the tongue weight was but it probably was a lot more that a smaller fiberglass. Seems like it was in the 600 + range. The Airstream dealer is the one that recommended it.
You also need to know what drop you need on it to level the trailer. I couldn't find the right one at HF recently, or at least the one near my house.
05-06-2018, 03:56 PM
Arkansas
A hitch extender does reduce the capacity of the hitch, because it moves the weight further away from the hitch. So, as you rightly point out, more leverage is exerted on the hitch assembly. But the claim of a 50% reduction is used for simplicity, and it is referring to the longer extenders that are around 14"-16" - not 1 inch. Will extending your stinger out 1 more inch reduce the hitch capacity? Technically yes, but probably not enough to be significant, and certainly not 50%. I agree also that if you have enough room on your ball mount to remount it further from the vehicle, that will work as well.
05-06-2018, 05:11 PM
I was also told my etrailers of a reduction but I was asking about mounting a motorcycle carrier on the front of my Tahoe with one of their front mount hitches. They were estimating that the 500 lb. carrier rating would be reduced to 350 lbs. which was still within weight specs of the motorcycle. They were not saying the hitch capacity would be reduced, just the carrier rating.
05-06-2018, 05:28 PM
It may have been a 10 or 12 inch extension that I looked at on etrailer. I agree that the 50% reduction is just an arbitrary figure for general information. I've seen it used for those double hitch extenders also. The leverage principal does affect the hitch capacity, but other factors like tongue weight will determine the percentage. The affect of an extension is sometimes overlooked, therefore my comments. Usage is an individual choice.
05-06-2018, 06:12 PM
Arkansas
Good point, it is worth noting. In some cases (like ours) a reduction in rated capacity wouldn't matter, because we're so far under the max for tongue weight, trailer weight, and hitch rating.
05-06-2018, 06:24 PM
Stability (sway) can also be affected by moving the ball further back. As with weight, an inch is one thing; a foot is another.
05-06-2018, 07:41 PM
Moving the hitch ball back will increase the chance of trailer sway, and increase the weight transfer onto your TV rear axle.
05-06-2018, 07:43 PM
Arkansas
Asked and answered above. We're talking an inch, not a foot. I seriously doubt there would be any discernable difference in handling.
