Solar(s) Panel(s), wich choose? - Page 5 - Fiberglass RV
Old 03-24-2016, 06:08 AM   #57
Originally Posted by Gilles View Post
I ordered it with the possibility of increasing the number of solar panels, installing a charge controller 30 amps, in case needs increase in the future, which appears unlikely....
Good plan.
I set up a 100 watt panel on a 14 foot cable that plugs into a trolling motor jack on the trailer (very water proof). I expect that I will mount this panel on the roof* and then get another 100 watt panel (or maybe the Renogy 2 x 50 watt suitcase panels) to use as a portable unit that I can position as needed to catch the sun's rays.
This way I get the best of both options... the roof mount requires no setup and works anytime it is in the sun, esp when on the road. The supplemental portable unit will require a little setup so will not be used unless needed. When it is needed I have more flexibility to get it into a location and set up at the angle where it works best.
* I found that deciding on the best way to roof mount a solar panel was the most difficult part of the entire project.
Old 03-24-2016, 06:29 AM   #58
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Originally Posted by gordon2 View Post
Good plan.
You watched this video to attach the panel to the roof?
I contacted "3M" this morning, so they tell me what they think ...
I await their response.
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 03-24-2016, 06:55 AM   #59
You watched this video to attach the panel to the roof?..
I have looked at the VHB tape option in great detail and while it might work, I have enough reservations that I have decided against it, at least on a Scamp It would take a long time to fully discuss my reasoning but a few of the highlights are that there are different varieties of VHB tape for different applications so you need to know which one to use. Some or all of the types is VHB tape do not seem to work very well on aluminum. Some VHB tape installs have failed, and at least one trailer manufacturer has stopped using it and gone to mechanical connection instead. In one case for example, it appears that the tape held OK but the gel coat that the tape was attached to actually separated from the fiberglass body (and the panel that flew off in traffic was never found). The liability of having a 16 pound panel blow off in traffic at 65 MPH is too great to take any chances so I am almost certain I will use through-bolts, well nuts, or the like, with stout backing plates. I think that using VHB or Epoxy takes a little more knowledge to do right compared to mechanical mounting. Mounting on a Bigfoot might be different.
Old 03-24-2016, 10:29 AM   #60
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
The panels on my trailer are bolted through the roof. Previous owner did it. Stainless steel bolts, and there are no leaks. I don't know if I would have done it this way, but at least I know the panels are not going to fly off.
Old 03-24-2016, 10:56 AM   #61
Trailer: R-Vision Trail Lite
Discovered ways to roof mount panels without drilling holes through roof.
Also learned that a space of about 2 inches is recommended between solar panel and roof surface for cooling of panels as heat buildup results in loss of power in solar panels....high heat=lower output.
Uplander is offline   Reply With Quote
Old 03-24-2016, 02:25 PM   #62
Idaho
More thoughts on solar
I'd like to make a few more comments on this topic, in response to what others have mentioned.
Cost: We all have our priorities when it comes to spending money on our FGRVs. I didn't spend a lot to buy my 72 Scamp, and I haven't put a fortune into it. It was just a solid shell on a new axle when I got it. Perfect for me. Blank slate. I've concentrated on interior design and comfort, mostly. On the outside, it still looks like an old 72 Scamp (except for those shiny panels ).
"Overbuilding" is not a fault, it just costs a little more, but not That much more. For me, solar power on my trailer is a grand science project....from those invisible, excited electrons all the way to cold beer in the fridge, I'm fascinated. So, like a hobby, I don't mind spending some money on something that is so much fun. Don't get me wrong, I'll waste hours on the internet trying to save a few bucks.
Extension cords: Most of the panels systems I have seen use MC4 connectors, which are solid and waterproof, and require a special tool (cheap) to separate them. I'm not sure if rigging extension cords would save much money, considering the crimping, soldering and shrink tubing that would be needed to make them suitable as weather-proof connections. And then there's the quality of the wire itself and the shielding that is used. The wires provided by Renogy are excellent, in my opinion.
Mounting or not mounting: Adding a remote, moveable panel is something I considered for months. The advantages of doing this are obvious, but the drawbacks may not be. How do you store this panel when moving, unless it's suitcase style, or you build your own case, or have the room to wrap it up and tuck it away safely. When you're on the road, a stored panel does nothing but take up space. Since I depend on solar for my fridge, this would be a disadvantage to me. Then there's the chance of theft. Solar panels look cool, and I think some people think they're worth more than they are. A panel on the ground might be a tempting heist to some.
And, one more thing.... I just might drive off dragging a panel behind me. But I guess that's a personal problem .
So, you've decided to mount to your roof: I trust expansion nuts (well nuts), and they work for me. I used 4 for each 100w panel. Big advantage: can be installed by one person using one wrench, and can be removed without a lot of trouble, if neccessary. Big scare: drilling 1/2 inch holes in your roof.
Flexible panels: Another option to consider, but read the reviews and compare the prices and warranties.
Performance: Photo voltaic cells begin working at sun-up and don't quit until sunset. Like hard working farmers, I suppose. They work in the shade and on rainy days. Just not as well. My point is this: they don't shut off. The amps are cumulative. On a bright, sunny day in June, my battery may be fully charged by 9-10 AM, and the panels have nothing to do for a while. Under less perfect conditions, it may take all day. And...., dusty panels can under-perform just like it's a cloudy day.
And so ends another long-winded post on solar. Obviously a favorite subject of mine. I try to share reliable info based on experience and research, but my education never ends. And I don't mind being called out on anything I've said. After all, I've been wrong before. Once or twice.
Gordon
Gordon in Idaho is offline   Reply With Quote
Old 03-31-2016, 09:12 AM   #63
Trailer: 77 Scamp 13
I have an awning track attached with VHB tape, not seen a whole lot of use but some fairly stiff breezes and my awning tarp is 10 x 12 so I would guess the tugging force is fairly high. However solar is typically attached with stand off brackets with not a large amount of surface area in contact with roof. That would be the issue I would want to address. Maybe with a rail or something that uses VHB that the stand-off brackets attach to. If I was attaching I would go with the larger panel.
30/40 watt panels are small enough to stow. You can Velcro strap them to fiberglass wall of closet. I like being able to park in the shade but move panel to sunlight, while being aware that as Gordon points out that is one more piece of stuff to be stowed or left at risk if I leave camp.
This seems like a question for one of the EE's but since driving down the road I have the battery being charged by the vehicle alternator how does that impact the solar charging. I'm assuming that the charge controller in effect being between the two charge sources will have an impact, just not sure what that impact would be.
Trolling motor plugs are another good and inexpensive option for connectors. I was mostly wondering about wire size in an extension cord. Seems to me since I plug into 110 volt source with an extension cord having one for portable 12 volt panel source would not be a big difference.
Old 03-31-2016, 10:06 AM   #64
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
In the past, Escape used 1" square aluminum tubing the length of the narrow side of the panel to attach the panel to the trailer & act as a standoff. The early trailers used VHB tape to attach the square tubing to the trailer, and they later changed to epoxy.
My panel is attached with VHB tape (installed in April, 2011) and it is still solid. They have had 2 failures that I know of that have been discussed on the Escape Forum, one with the tape & one with epoxy. In the case of the epoxy failure, the gel coat separated from the trailer fiberglass shell; apparently, the epoxy didn't fail. Both failures were while driving in severe crosswinds. In any case, they provided owners with additional attachment kits & are now bolting the panels to the roof.
Old 04-08-2016, 03:16 PM   #65
honda03842's Avatar
Name: Norm and Ginny
I've had a solar panel attached directly to the Scamp 16's roof surface (gel coat) with Scotch exterior vhb tape for about 5 years. No issues what so ever. I was able to remove two 40 watt panels and replace them with a single 100 watt panel. No damage to the surface. We travel pretty extensively in all kinds of weather. One advantage is our panels are no more than a 1/4 of an inch off the roof surface.
Sent from my SM-N920T using Fiberglass RV mobile app
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2016, 09:19 PM   #66
Gilles's Avatar
Quebec
Thank you very much for your positive comment, fix the panel with VHB tape, this is how I decided, having read and seen a lot about ...
Having secured with tape 3M VHB RP25 2 inches wide, I protect from dirt, sun and weather, with a layer of the protective tube.
Have a good season.
Gilles
Bigfoot 15B17G.
Old 04-08-2016, 10:49 PM   #67
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Long standing recommendations for the mounting of solar panels suggest a 3-4 inch air space under the panels. The air space under the array helps lower PV module temperatures; cooler modules produce more electricity than hotter modules.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 04-09-2016, 09:33 AM   #68
Radar1's Avatar
Name: Dave (and/or John)
Originally Posted by Gordon in Idaho View Post
And I recommend this controller because it shows you real time amps in and amps out; amp hours in and amp hours used; among other useful stuff. It's very good to know how much current the sun is providing, as well as knowing how much electricity you're devices are using:
P30L LCD 30A PWM Solar Panel Regulator Charge Controller with Digital Display and User Adjustable Settings
When you add in mounting brackets, extension cables, and battery cables, it's not cheap but, there's a unique joy in using the power of the sun.
Happy camping,
Gordon
Hi Gordon,
I have the same controller as you. Have you connected your LOAD lines into your 12 volt system yet? I'm a bit fearful of doing that because it seems that any charging done by either the converter when on shore power, or TV while towing, would go directly back through the LOAD output. Would that damage the controller, or would adding a diode prevent any potential damage?
I did run a separate circuit from my LOAD output to a dedicated circuit for my 12 volt outlets, used to power my TV/DVD and CPAP machine, plus reading light and radio. That way I'll be able to measure how much power those devices consume immediately and cumulatively.
I would love to tie the whole DC circuit in so I could also measure the pumps, other lights, and fans.
My current setup includes a 90 watt panel permanently attached to our 16' Scamp roof with VHB tape, and a portable 90 watt panel that can be set up wherever the sun shines to help the permanent panel as needed.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 04-09-2016, 12:13 PM   #69
Idaho
Hi John,
I can only give you a partial answer. Yes, everything that requires electricity in my Scamp is fed off the Load terminal of the controller. I use this fuse panel, located about 10 inches from the controller:
Amazon.com : Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover : Fuse Block With Relay : Sports & Outdoors
I have 10 of the 12 branch circuits in use, plus this sub panel in the back of the trailer with 4 more fused lines.
Amazon.com: Sea Dog 422010-1 Aluminum Vertical 4-Switch Panel: Automotive
Miles and miles of wire....
I called Windy Nation last year with questions about using the Load output as opposed to running everything directly off the battery, and I was told that it's OK as long as you don't draw more than 30 amps. Don't try to hook up an inverter this way!
I like being able to isolate different devices and learning how many amps they use. One of these days, when I'm sure my battery is top shape, I'll have to stress the system by turning Everything on at the same time, and that means fridge running, all lights on, furnace blowing, water running, DVD playing through the amplified stereo system, and charging a phone and Kindle. I'll let you know what happens.
But, I don't have any means of using shore power or my TV's alternator, but I would Assume they would provide regulated power directly to the battery, and not feed back to the controller. As i understand it, if the controller reads a full battery, it stops providing charging power until needed. Maybe another forum member will be better able to answer that question.
So, that's what I Think I know. I'm not sure about all the science involved, but I know what works for me.
Gordon
Old 04-10-2016, 10:54 AM   #70
Gilles's Avatar
Quebec
Hello to both of you,
I just want to check with you if I shopped the perfect tape to secure my solar panel.
3M VHB RP25 (2 inches wide)
Temporarily out of stock on Amazone.ca
https://www.amazon.ca/TapeCase-Width...5rp+2%22+width
The Z Brackets of the panel to stick on the roof have as 1.50 inches by 4 inches area.
Gilles
Bigfoot 15B17G.
solar
How do I choose?? FishBioGirl General Chat 8 10-08-2013 09:17 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Which small trailer would you choose? Joel3217 Towing, Hitching, Axles and Running Gear 12 05-13-2008 09:13 PM
Canadian Solar Panel Barbara Gardin Electrical | Charging, Systems, Solar and Generators 5 04-01-2006 06:34 PM
Which small trailer would you choose? Joel3217 General Chat 0 12-31-1969 07:00 PM
