Solar(s) Panel(s), wich choose? - Page 6 - Fiberglass RV
Old 04-10-2016, 04:22 PM   #71
Radar1's Avatar
Name: Dave (and/or John)
Originally Posted by Gilles View Post
Hello to both of you,
I just want to check with you if I shopped the perfect tape to secure my solar panel.
3M VHB RP25 (2 inches wide)
The Z Brackets of the panel to stick on the roof have as 1.50 inches by 4 inches area.
Gilles,
I used the same VHB RP25 tape, except mine was only 1" wide. I used a 1x1x36" aluminum angle piece cut into four 9" sections for each leg and bolted the Z brackets to them. (9 sq inches of surface area at each corner)
I had to bend the brackets a little from perpendicular due to the side to side curvature of the Scamp roof, and the front brackets were modified to also meet the increased front curvature of the Scamp roof. From the photos you can see that 1/3 of the front angle had the upper section cut away so I could bend the foot to the curve.
One lucky part of having the Scamp with the large fridge is that it includes an upper vent, so I was able to run my solar wiring down that vent without resorting to any new holes in the Scamp roof.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 04-10-2016, 08:40 PM   #72
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Originally Posted by Radar1 View Post
Gilles,
Thank you very much for your testimony.
For my curiosity and that of other members who are interested about, what capacity your solar panel and your apreciation of it?
Thanks in advance,
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 04-11-2016, 09:45 AM   #73
Radar1's Avatar
For my curiosity and that of other members who are interested about, what capacity your solar panel and your appreciation of it?
Thanks in advance,
We have a 90 watt panel on the roof that fills our needs when we have sunlight, plus another 90 watt panel we can deploy up to 40 ft away if the sun isn't hitting our camper.
So far we have been happy with the results using our type 29 12 volt battery but hope to upgrade to two 6 volt golf cart batteries next battery change for double the capacity in case we run into dark rainy weather further North. Less sunlight up North in the winter months.
Sharpsburg, GA
solar
How do I choose?? FishBioGirl General Chat 8 10-08-2013 09:17 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Which small trailer would you choose? Joel3217 Towing, Hitching, Axles and Running Gear 12 05-13-2008 09:13 PM
Canadian Solar Panel Barbara Gardin Electrical | Charging, Systems, Solar and Generators 5 04-01-2006 06:34 PM
Which small trailer would you choose? Joel3217 General Chat 0 12-31-1969 07:00 PM
