Soot from water heater - Fiberglass RV
Old 05-27-2015, 02:46 PM   #1
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I've started to have soot buildup on the outside of my water heater vent.
I assume it means I need to clean the orifice but would appreciate learning anything from other's experiences.
Walt
WaltP is online now   Reply With Quote
Old 05-28-2015, 03:31 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Had a little bit of that too 30 years ago. If I remember right, the air mix slide on the burner moved a bit and changed the burner enough to cause a dirty flame. I know I didn't clean anything out, just moved the gap cover until the flame was the right color. May or may not be your problem. Kind of surprised no one has got back to you yet.
Borrego Dave is online now   Reply With Quote
Old 05-28-2015, 05:01 AM   #3
KenjiFox's Avatar
I agree, adjust the air intake tube. Soot indicates to me that the flame is running rich rather than lean. This means that your orifice is not plugged, but the air intake may be.
I know that a spider had made a nest inside of my air tube and plugged it up completely.
You can take the tube off and blast it out with compressed air. Once you know it's clean re-install it and light the heater.
Adjust the air intake so that the flame is mostly blue, with a slight roar to it. Not a loud one that you can hear from inside the trailer, but not quite silent either.
KenjiFox is offline   Reply With Quote
Old 05-28-2015, 05:40 AM   #4
WaltP's Avatar
SW Virginia
Thanks both. Sounds very helpful.
Walt
Old 05-28-2015, 09:28 AM   #5
kevin57's Avatar
Trailer: Miti-Lite
I agree. Also blow out burn chamber/heat exchanger as something also could be in there burning up. If not getting that nice blue gental jet flame with minimal Orange coloing at tip as they were talking about after adjusting air mixture tube you will want to check lp pressure to your valve. If you don't take your Rv to a service center regularly and like to do your own service work you will want to own an Manometer to regularly check your lp system for safe and proper operation. A great artical everyone who owns and Rv with an lp system should read is this : The RV Doctor: What the Pro's Do - Propane System
In short for your water heater to have a good flame and all your lp systems to work properly and safely you need to make sure your lp regulator is providing 11" w.c under system load. There is a gas tap on the w.h. Gas valve (flush mount allen head screw) you can tap into and hook your manometer to it and see what the pressure is like with the valve in opeation. I hope you get that sucker roaring for you soon!
"Always look on the Lite side of life" - Eric Idle
kevin57 is offline   Reply With Quote
Boler water setup??? new tank, pump & water heater question Johnny M Plumbing | Systems and Fixtures 7 05-07-2015 12:41 PM
Terracotta Radiant Heater, Instead of a catalytic heater Adrian W General Chat 13 06-05-2011 02:14 PM
Soot Stain on Trillium 1300 Brian Gibbon Problem Solving | Owners Helping Owners 0 04-18-2010 06:58 AM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
