Source for door hinges? - Fiberglass RV
Old 12-17-2008, 03:25 PM   #1
Vic&Kathy's Avatar
Trailer: Trail Mite
I'm in the midst of refurbishing our beloved '72 Trail Mite.
With all the NEW going on it's hard to think about continuing to use the original worn-out hinges on the door. Are new replacements available, or will I need to resort to used-but-serviceable?
I've already pulled the shell off the frame, put down new marine plywood floor, reinforced the frame with some added struts and repaired some marginal welds and reset the shell on the frame.
I have a new ice-box, stove hood/fan am getting a Fantastic Fan ceiling vent and will have the whole thing re-wired soon. I also hope to have the time (and $$) to put a solar panel on it before our annual June/July trip across the US and back.
Last year I replaced the axle and springs, raised it up 4", installed brakes and a tongue box. Ah yes, an ongoing project.
Thanx!
Vic
Vic&Kathy is offline   Reply With Quote
Old 12-17-2008, 03:58 PM   #2
Raya's Avatar
I think your hinges might be the same as Scamp hinges since they have three fasteners on the camper side. Bolers have a similar type but with only two fasteners on the camper side.
Scamp sells hinges complete, or kits to rebuild the guts (which also work on the Boler hinges).
Scamp has a website, but best just to call them for parts. 800-346-4962.
Couple of notes:
1) It seems that they use non-stainless bolts and nuts in the hinge kits, so you'll probably want to substitute different ones when you get them.
2) One "set" is one hinge, not a set of two hinges. Also, I *think* that hinge #2 goes on the bottom, and hinge #1 on the top, but you can probably check how they match up to the ones you're taking off.
Their prices seem reasonable, too.
Rachel
Old 12-17-2008, 04:44 PM   #3
Harry Young's Avatar
Post
I think that is a marine snap apart hinge at least a derivation of one. http://www.jamestowndistributors.com/userp...ap+Apart+Hinges
this other link is the whole shooting match of all kinds of hinges.
http://www.jamestowndistributors.com/userp...31&refine=1
I agree they look like scamp hinges too.
Harry
Old 12-17-2008, 04:51 PM   #4
Vic&Kathy's Avatar
Trailer: Trail Mite
I think your hinges might be the same as Scamp hinges....
Rachel,
Thank you! I knew that someone on here would have the info.
I looked at the Scamp site. Their hinges look very similar, except maybe the shell side might have slightly different hole spacing. I'll order them anyway and may need to fill a hole or two and re-drill another hole or two.
One more item off the list!
Vic
Old 12-17-2008, 06:10 PM   #5
Joe Z's Avatar
New River AZ
Maybe this place could help
Joe
http://www.vintagetrailersupply.com/Door_s/10.htm
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Source for Window on Door? Vic&Kathy Problem Solving | Owners Helping Owners 2 06-30-2010 12:19 PM
Compact Jr - Aluminum Door sill/frame source? bgeery Problem Solving | Owners Helping Owners 5 09-21-2009 02:49 PM
Door Hinges Wayne Boone Problem Solving | Owners Helping Owners 5 04-18-2008 09:05 PM
Looking for some Door Hinges.... mcnick Problem Solving | Owners Helping Owners 23 06-18-2007 06:52 PM
Looking for some Door Hinges.... mcnick General Chat 0 12-31-1969 07:00 PM
