Spare Tire Mount - Fiberglass RV
Old 06-08-2008, 07:44 PM   #1
Trailer: 1977 Boler 13 ft
my spare tire mount i found out is in quite bad shape. Patched and fixed quite a few times buy the look of it with sillycone and seems what ever was around at the time. Has anyone reinforced the fiberglass with anything i'm thinking on putting in a plate of aliminum inside and out to brace the weight of the tire and wheel on exterior fiberglass. Just wonderin if anyone had some good ideas on how to fix this. Thanks Peoples
Johnathan Gallant is offline   Reply With Quote
Old 06-08-2008, 09:12 PM   #2
Roy in TO's Avatar
I'm not sure how bad things are. If they are really bad, Jean L has made a spare tire mount that attaches to the rear bumper that is quite nice. (It is on my list of upgrades). Before I seen Jean's work, I reinforced mine and it is holding up well.
I took a square SS U bolt and had to bend it slightly in the middle to fit the bolt pattern. Then I held a small plate with 2 rubber washers to the U bolt. All this goes on the outside of the rim.
On the inside, I used a plate of SS metal with a couple of holes drilled in the right spot, then used 2 of the original washers that were on the original tire mount, 2 lock washers and 2 SS acorn nuts. It took a couple of tries to get the length of the U bolt just right for the acorn nuts to fit.
I went this way because the original bolts were really rusted I could not get them apart. All the connections are now on the inside away from the elements. The acorn nuts are a little safer for the person sleeping next to the wall (me). It also makes it a little more difficult for someone to steal the spare. That's a lot more important in a city of 2.5 million people than I would expect it to be in PEI.
It takes 2 to mount the spare, 1 hold the ubolt and tire in place from the outside while the other puts the nuts on from the inside. It takes only one to remove the spare.
Old 06-09-2008, 07:35 PM   #3
Thanks for the tips im going to check out jeans work and see what i can construct.
Old 06-10-2008, 06:24 PM   #4
Trailer: 2 American Bolers
Connecticut
Hi Johnathan
Here's a couple pictures of my tire mount
Jean-l
JEAN-L is offline   Reply With Quote
Old 06-10-2008, 06:40 PM   #5
Harry Young's Avatar
That fabricated tire carrier is a nice job.
You can get a bolt on one that bolts to the bumper and get it welded. http://www.harborfreight.com/cpi/ctaf/disp...temnumber=93341
You cannot buy the steel for this price.
Harry
spare tire Vicki A. General Chat 9 03-09-2010 01:00 AM
uhaul spare mount Judith Kennedy Care and Feeding of Molded Fiberglass Trailers 1 10-12-2009 09:58 AM
scamp 4 lug spare tire mount pic? andy vaughan Problem Solving | Owners Helping Owners 11 12-31-2008 01:30 PM
Spare tire Lainey Problem Solving | Owners Helping Owners 1 08-12-2007 06:48 AM
under spare tire christineb Problem Solving | Owners Helping Owners 10 01-25-2007 06:58 AM
