Spare Tire Mounting - Fiberglass RV
Old 03-15-2013, 05:30 PM   #1
jack smith's Avatar
Trailer: Scampless in Oregon
Spare Tire Mounting
In the course of going over my "new" Scamp ("Sweet 16") I took off the spare tire and noted the black rubber stains as the tire had been quite "snug" against the body. After cleaning I readjusted so that there would be a slight space between the tire and the body... and noted that there would be some vibration when underway...
My question is: will this vibration lead to cracking of the fiberglass? Should I keep the tire snug against the body? Any suggestions or comments? What do you "experienced Scampers" do?
(If snug against the body the tire cover will not fit properly...)
jack smith is offline   Reply With Quote
Old 03-15-2013, 05:39 PM   #2
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
If it's mounted through the fiberglass like mine was, do not let it wobble around. Mine cracked out anyway, although it's hard to know the history being almost 30 years old. I'm not going to have the spare mount on the fiberglass again. I carry two spares, so one would have to be in the pickup either way, so I'm just throwing both in there. Also, my spares are shared between my trailers so they move around, anyway.
Old 03-15-2013, 06:39 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Yes, it will shake all over the place when you hit bumps.
Yes
Yes
On my UHaul I made a tire mount to the bumper / frame
Yep
Old 03-15-2013, 06:52 PM   #4
Could you see the black marks when the spare was mounted? If NO, why worry about it? I know from reading all the forums that tires out gas, and that means black marks. Some have wrapped the tire in dry cleaning bags then reinstalled a spare tire cover. But my question becomes... what happens to that "gas"? Is more harm being done by trapping it?
Don't let the tire wobble... that would be worse than the stains that maybe you can't see when the tire is mounted.
Old 03-15-2013, 07:06 PM   #5
jack smith's Avatar
Well... guess I already knew what the answers would be...
... kinda a no brainer, actually. Thanks all!
Old 03-15-2013, 08:26 PM   #6
Hey Jack, you have to ask the questions to either be verified or no go.... hope the responses helped somewhat
Old 03-15-2013, 10:03 PM   #7
chse's Avatar
Trailer: 13' Scamp
I had the same thoughts with my 13'. The spare tire mounting really does not seem optimal. You can by spare tire mounts which attach to the bumper (check etrailer f.e.) the problem is that they mount the tire behind and not above the bumper.
chse is offline   Reply With Quote
Old 03-15-2013, 10:44 PM   #8
Chris the problem with using the spare tire mounts that attach to the bumper is that Scamp really didnt build their bumpers to support much of anything. So if you have a tire attached to it could lead to some not so great issues down the road.
Jack my spare is mounted very tight to the trailer as well and getting the tire cover on and off can be a challenge as well. Have found putting it on at the top half first works the best.
Old 03-16-2013, 07:54 PM   #9
jack smith's Avatar
That's kinda how it was mounted when I took it off... after looking at the etrailer mounts... and my angle iron bumper... think I'll just put it back on like it was! However, as I'm typing this, am thinking of some sort of "spacers" double side taped on the body that would allow the tire to be snugged up tight... and still leave a bit of space for slipping the tire cover over the tire.... hmmm
Could beef up the bumper and build something... but not really wanting to go at this in such a "serious manner!"
Old 03-16-2013, 09:45 PM   #10
Jack are you saying your tire is mounted on the bumper and not mounted right onto the rear of the trailer with a couple of bolts that come up below the rear window? If so that must be a fairly new way for Scamp to be doing them.
Old 03-17-2013, 07:16 AM   #11
jack smith's Avatar
No Carol, my tire is mounted as per Scamp: three threaded rods through the back of the body. I have merely contemplated changing to a bumper mount... but have pretty much ruled that out.
Old 03-17-2013, 07:11 PM   #12
chse's Avatar
Trailer: 13' Scamp
Thanks for the warning- I thought it seemed pretty sturdy.
I guess another option would be a hitch receiver (I saw one at amazon) and tire mount - but thats a bit pricy... but I could put the wheel in the camper and mount some bikes if needed.
Old 03-17-2013, 07:19 PM   #13
jack smith's Avatar
Doesn't the hitch receiver also mount to the bumper? The bumper seems fairly stout, but the fact that it is angle iron as opposed to boxed... therein I think lies the problem when it comes to clamping something to it...
Need Help:Spare tire and Rim Ana A in NJ Problem Solving | Owners Helping Owners 13 04-24-2012 07:52 AM
spare tire Vicki A. General Chat 9 03-09-2010 01:00 AM
Spare tire Lainey Problem Solving | Owners Helping Owners 1 08-12-2007 06:48 AM
Trillium 4500 spare tire mounting Joe Loiacono Problem Solving | Owners Helping Owners 4 07-20-2007 09:36 PM
under spare tire christineb Problem Solving | Owners Helping Owners 10 01-25-2007 06:58 AM
