Spare tire on back of trailer - Fiberglass RV
Old 05-09-2009, 11:38 AM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
How tight should the spare tire be on the back?
1 Tight to the fiber glass trailer (Then it rubs on the trailer, also could rub a hole in the fiberglass)
2 Not touching the fiberglass trailer ( It jiggels on the back of the trailer could break the mounting bracket or could crack the fiberglass at the mounting area)
Old 05-09-2009, 04:38 PM   #2
Pete Dumbleton's Avatar
I kept mine pretty tight on my Alaska trip and the raised lettering imprinted itself on the fiberglass, but I doubt it would wear a hole with the whole surface in contact, at least not in my lifetime. Strangely, the lettering on the tire didn't wear off...
You might try a doughnut of plastic foam between the tire and fiberglass.
I don't worry about it because the tire covers the blemish.
Old 05-09-2009, 05:57 PM   #3
james kent's Avatar
Trailer: Boler 1984
Here's the bracket I made from a piece of tubing, some bolts and a couple of short pieces of pipe from CTC. It holds the spare about 1 inch from the trailer and even with hard knocks it doesn't touch.
Old 05-09-2009, 07:01 PM   #4
I wanted my tire firmly touching the fiberglass so there was less stress on the bracket and glass, esp on some of the rough roads I often travel.
Old 05-09-2009, 08:45 PM   #5
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
Pete, I feel the same way you do, Actually I took the tire off and spun another nut onto the threaded rod but way out from the trailer then took a piece of steel 1/2" thick by 1-1/2' wide by about 7 or 8" long drilled a clearance hole in the middle of the steel bar then put that on the rod before I put the tire on. I then put the tire on , the big washer on and tightened it up against the nut and bar. I then measured the distance from the back of the tire to the trailer and in my case it came out to be 7/8". I then took the tire back off and turned the nut in toward the trailer about 1-1/4" and then put everything together again. Now I can tighten it as tight as I want to because its just tightening against the new nut and not the trailer.
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
spare tire Vicki A. General Chat 9 03-09-2010 01:00 AM
Spare tire Lainey Problem Solving | Owners Helping Owners 1 08-12-2007 06:48 AM
Spare Tire Rim Nancy and Don Ostaff Problem Solving | Owners Helping Owners 5 08-08-2007 06:52 PM
For Sale: New Spare tire Marilyn Teleck Classified Archives 1 04-17-2007 07:13 PM
under spare tire christineb Problem Solving | Owners Helping Owners 10 01-25-2007 06:58 AM
