Spare Tire Rack - Page 2 - Fiberglass RV
Old 04-22-2003, 12:27 PM   #15
my solution
Had a std tire carrier welded to bumper when I went from 13" to 15" wheels. The allthread was shortened but left intact to support the top of the carrier by double nutting.
Old 04-22-2003, 12:28 PM   #16
Orginally posted by Suz
* * * * * * Benita, *since your Fiber Stream is a tandem axle, do you have ST175R13s? *
I'm going out to check on it in a few days, I'll take a look then.
Old 04-22-2003, 12:30 PM   #17
Tom and I made a camping trailer a few years back . it was only to hold the equipment and to pull behind the jeep. box about 4x6 and we bolted the spare to the tongue, then put the tank inside the wheel. worked great. but as you can see it didn't work in the picture. so my proportions are off. :lol
<img src=http://www.fiberglassrv.com/board/uploads/3ea5892bcc7e2Picture2.jpg/>
this picture was somebody else's drawing. I just tweaked it.. You know me and tweaking. (thanks to whom ever the artist of the trailer was, sorry I can't remember to give credit :red )
Old 06-30-2003, 04:30 PM   #18
I might try this
If this doesn't cause too many clearance problems under the tongue, this might be a solution.
A question: My trailer did not come with a tire carrier anywhere. (The tire was on the floor under the dinette.) If this under-tongue solution does not work, where would I get a carrier for the back bumper, which allows the tire to rest on the bumper?
http://www.fiberglassrv.com/board/uploads/...rrier.jpg/>
Old 06-30-2003, 05:07 PM   #19
My solution
Sorry if you've seen this picture elsewhere, but I thought it appropriate for this thread.
Working out where to put tire took a lot of thought as you all have been doing.<img src=http://www.fiberglassrv.com/board/uploads/3f00c26fa577brackdown.jpg/> <img src=http://www.fiberglassrv.com/board/uploads/3f00c28689cf6rack-up.jpg/>
Old 06-30-2003, 08:09 PM   #20
Suz,
I had the same problem when I converted to 14 inch tires and I looked at all of the solutions offered by factory made tire mounts. I purchased one like the one in the photo that Joe posted but the tire hung so low that hit the pavement when going over any small dip. The solution was very simple. I just cut a new disk to replace the one that Casita made from scrap fiberglass and drilled the hole off center to compensate for the larger diameter tire and wheel. I made the new disk out of an old plastic cutting board.
Old 07-01-2003, 10:41 AM   #21
Spare Tire Rack
Thanks for the tips. Somehow, I ended up with two threads on this. Here's what I finally came up with. I have been extremely pleased with it. It not only cured my spare tire dilema, it solved my light tongue weight problem, also.
Suz's spare tire rack
spare tire Vicki A. General Chat 9 03-09-2010 12:00 AM
Spare tire rack? Randya Modifications, Alterations and Updates 9 03-08-2009 06:33 PM
Spare tire Lainey Problem Solving | Owners Helping Owners 1 08-12-2007 06:48 AM
Spare Tire Rim Nancy and Don Ostaff Problem Solving | Owners Helping Owners 5 08-08-2007 06:52 PM
Spare Tire Rack Legacy Posts Modifications, Alterations and Updates 5 05-15-2003 07:39 AM
