Spideweb cracks in the ceiling - through the fiberglass - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 08-29-2015, 03:39 PM   #1
Name: T and K
Trailer: Ventura
Spiderweb cracks in the ceiling - through the fiberglass
Wanted to get a couple different opinions on how I should best tackle this. From the inside I can see the spiderweb cracks and upon closer inspection it looks like it's not just the gel coat that is cracked but the fiberglass as well because there is moisture coming in through them and in some areas mold.
Hoping an interior fix would work - don't want to have to strip the exterior to fix it that way.
This is all on the ceiling of a 1975 Ventura. posting this on my phone, I will try to add pictures but if it doesn't work I will add pictures later from my computer
Sent from my SGH-I727R using Fiberglass RV mobile app
OnTheRoad is offline   Reply With Quote
Old 08-29-2015, 06:26 PM   #2
Looks to me like it was struck on the outside by a heavy object. If I owned it, I would get rid of the mold on the inside and do a repair on the outside. A really simple temporary patch on the outside could be as Easy as some really strong tape. Then when I had the time I would sand the outside and apply some gel coat.
Old 08-31-2015, 12:25 PM   #3
Name: T and K
Trailer: Ventura
We were planning on doing the gel coat on the outside this month anyway so it doesn't create a huge amount more work for us.
Scrubbed the inside with bleach and a stiff bristle brush yesterday, still looks about the same but a lot of the black is in the layers of fiberglass - only some of it looks like it actually came through.
Might hit it with bleach again, and then I think I am going to roll on a few coats of glassing epoxy on the inside just to seal all that crap in... if I can't get to all the potential mold in the fiberglass layers to remove it I'm just going to encase it!
Scamp stainless bolts roof through ceiling Foxtrots Care and Feeding of Molded Fiberglass Trailers 8 03-11-2014 08:00 PM
Crack "Through and Through" Hatchway Mr Jimmy Modifications, Alterations and Updates 13 01-10-2014 12:33 PM
Fiberglass cracks Janne Potter Problem Solving | Owners Helping Owners 3 04-25-2011 02:53 PM
Nails Poking through Fiberglass Pamela S. Problem Solving | Owners Helping Owners 7 04-21-2010 09:40 AM
How do you fix Fiberglass cracks SharonNDean Problem Solving | Owners Helping Owners 12 02-12-2008 09:46 PM
