Splintered OSB neat water tank drain - Fiberglass RV
Old 10-15-2014, 05:40 AM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Howdy folks,
When scamp blew the hole through the OSB for the water tank drain it splintered. I glued it back up last night (3.5" by 1.5" hunk) and painted it a bit.
Would like to seal it somewhat but don't have skill to use glass. Can anyone recommend a product that would give that nice glossy seal like glass, that I could perhaps paint or spray on? Just a little area, but it is raw wood now and I'd like to protect it somewhat.
Cheers!
Wendy
Old 10-15-2014, 05:55 AM   #2
Wally World sells a qt. container of polyester resin in the auto body section. Just mix part A and part B as directed. Wear disposable gloves and get a throw away brush from the dollar store. Just paint it on. No need for glass cloth if you are just trying to seal the wood. (The resin will dry clear.)
Eddie
Old 10-15-2014, 06:44 AM   #3
Trailer: Class A Motorhome
MinWax has a product called "Wood Hardener" that is designed to seal up water damaged wood, that may also do the trick with a few coats. No mixing, no leftover stuff, just brush it on. After it dries, you can cover the wood hardener with clear spray varnish if needed. Available at most any hardware store, other brands may exist.
Old 10-15-2014, 07:11 PM   #4
Dan Meyer's Avatar
Anything is better than nothing. If it were me, I'd use 2-3 coats of flat black spray paint.
-- Dan Meyer
Old 10-18-2014, 03:49 AM   #5
CampyTime's Avatar
I did put on the Minwax Wood Hardener last night and would like to apply Helmsman outdoor polyurethane this am if weather cooperates. Thank you folks for all the great ideas- each one of them a gem!
plastic knob to drain water tank rotted again Karalyn Plumbing | Systems and Fixtures 18 05-14-2013 06:21 AM
Neat truck camper....not fg... but still neat cpaharley2008 General Chat 6 06-16-2012 03:04 PM
Floor replacement Options - OSB vs Plywood. Oliver P Problem Solving | Owners Helping Owners 11 08-11-2009 08:34 PM
Trillium water tank drain John Perry Problem Solving | Owners Helping Owners 5 10-15-2007 08:59 PM
Water tank drain Lee Hillsgrove Problem Solving | Owners Helping Owners 3 07-01-2007 08:41 PM
