Squeaky Utensil Drawer (nails on chalkboard quality!) - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 07-13-2016, 04:11 PM   #1
Ohio
Hi. We bought a new 2016 Scamp this past Spring and the noise when opening/closing the utensil drawer is driving me batty! The only way to get relief is to pull up on the knob while pulling it open, but that doesn't always work. My husband tried oiling the tracks but it didn't help. Anyone else have this issue and find a solution?
Sue H G is offline   Reply With Quote
Old 07-13-2016, 04:19 PM   #2
I use a tea candle ( wax ) on my patio door to get rid of noise opening and closing.
Just rub it on the track.
Old 07-13-2016, 04:43 PM   #3
Trailer: Trails West
It is likely an issue of settling and/or warping causing a pinching situation. Not at all unexpected in something brand new. You can get dimensional creep in materials especially if the product changes climate locations. Or maybe the installer in the factory did not get the final adjustment done just right.
I would try loosening the screws (just back them off a half a turn or so) that hold the track in place and then see if you can get some adjustment to relieve the binding situation that might be causing the noise. The track will want to settle in to where there is no binding stress, then tighten the screws back up.
Old 07-13-2016, 04:46 PM   #4
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
I would try loosening the screws that hold the track in place and then see if you can get some adjustment to relieve the binding situation that might be causing the noise.
Ours made a racket as well. It was the drawer bottom rubbing on the fiberglass body of the galley. Not unlike a bow on a cello string. Without "trimming" that fiberglass back some, a job I did not wish to take on, the sound wasn't going to go away. So, we lived with it's annoyance.
bpfick is offline   Reply With Quote
Old 07-13-2016, 04:53 PM   #5
Try rubbing the sliding parts with a bar of soap.
Old 07-13-2016, 04:57 PM   #6
Wax works better than soap.
From experience.
Old 07-13-2016, 05:43 PM   #7
Ohio
Thank you all for the great ideas! Will definitely loosen the screws as attempt #1 then proceed with wax, etc if needed.
Old 07-13-2016, 08:17 PM   #8
JackieLynn's Avatar
Kansas
We had the same issue. I didn't think of trying to loosen the screws and adjusting the tracks--that would have been easier. I used a file and took out some of the fiberglass.
JackieLynn is offline   Reply With Quote
Squeaky Scamp 19 door hinges? Stretcher Problem Solving | Owners Helping Owners 6 06-15-2014 01:31 PM
Squeaky Floor jimmied Modifications, Alterations and Updates 3 10-21-2012 11:55 AM
Liquid Nails Wallo Problem Solving | Owners Helping Owners 4 01-22-2012 03:35 PM
Nails Poking through Fiberglass Pamela S. Problem Solving | Owners Helping Owners 7 04-21-2010 09:40 AM
Utensil/silverware drawer DianeP Modifications, Alterations and Updates 10 04-21-2006 09:09 PM
