Stabilizer Jacks - Fiberglass RV
Old 06-24-2015, 01:44 PM   #1
Stabilizer Jacks
What are best Stabilizer Jacks for 1980 Boler. The ones that came with the Boler are Jack Stands for a car.
immrbill is offline   Reply With Quote
Old 06-24-2015, 03:31 PM   #2
The Minimalist's Avatar
Louisiana
For a real lightweight like the Boler, I would recommend these. There are other companies that make this design, but I don't know the quality.
Atwood Stabilizer Jack - 6-1/4" Drop Leg Travel - 17-3/4" Ext - Black - 650 lbs - Qty 1 Atwood Trailer Jack AT82301
These are easy to set up and adjust. We have two on the rear of our Little Joe. When leveling the trailer we jack the front until it's a bit low on the front end, drop and extend the stabilizers and then jack until level.
Clif
Old 06-24-2015, 03:43 PM   #3
How would these install on a Boler.
Old 06-24-2015, 05:04 PM   #4
Louisiana
Mine are through bolted to the outer ends of the bumper, which puts them about even with the inside of the tires. Looking a Bolers in the Gallery, I see that the bumper mounts are closer to the center line of the trailer. This would be the easier way to do it, but not as stable. The only other option would be to put them on the rear of the frame itself. You might look under there to see if there is access. I'm not familiar with the way the Boler is mounted on the frame. Hopefully, who has used these on a Boler will be able to share their experience and/or method of mounting.
Clif
Brackets for Stabilizer Jacks Jane D. Problem Solving | Owners Helping Owners 9 09-09-2011 04:10 PM
Stabilizer Jacks jimtesla Care and Feeding of Molded Fiberglass Trailers 21 06-19-2010 02:39 PM
Stabilizer Jacks for a Lil Bigfoot Carl G Towing, Hitching, Axles and Running Gear 2 05-10-2009 07:28 PM
Cleaning up the stabilizer jacks Per Walthinsen Modifications, Alterations and Updates 1 04-12-2006 10:13 PM
Stabilizer Jacks Legacy Posts Modifications, Alterations and Updates 17 05-08-2003 05:04 AM
