Sticky door hinge on Trillium - Fiberglass RV
Old 11-20-2013, 12:33 PM   #1
Trailer: Trillium 1300
Anyone else encounter this problem?
In the past couple of weeks, the top hinge of the door of our 2011 Trillium has become very stiff. Previously the door swung freely in both directions (a light breeze would push the door shut), but now I must put real pressure on the door to open and close it.
I'm pretty sure the problem is the top hinge, as I can see the strain it is putting on the trailer-side hinge mount. I tried applying some silicone lube, but there doesn't seem to be an easy way to get the lubricant into the mechanism.
I'm afraid if I use the door only a few more times, I'm going to damage the mount and the trailer for real.
Thoughts?
mzuzel is offline   Reply With Quote
Old 11-20-2013, 01:18 PM   #2
Raz
Raz's Avatar
Vermont
Hello Michael and welcome to the forum. Is your Trillium US made or Canadian? Mine is US and came with hinges that were not aligned properly. Not sure if this will help but maybe.
Trillium Hinge Repair
Here is what the hinge looks like apart. The pin is splined and can be removed by tapping on the narrow end with a small dowel. Raz
Old 11-20-2013, 01:58 PM   #3
Thanks, Raz. Yes, ours is a US Trillium. Weird that the door has worked fine through three seasons only to go flaky on us now. Maybe I'll start by removing and cleaning the pin and see if that helps.
Old 11-20-2013, 02:29 PM   #4
Raz
Raz's Avatar
Vermont
I'm not sure you have the same issue. I would suggest you make a "tool" like mine, two nails in a piece of scrape lumber, to check your screw separations. I used the screws on the door closest to the rear as " correct". Because they are Phillips screws any variation will show. Raz
trillium
Door hinge repair Artann Problem Solving | Owners Helping Owners 0 11-05-2013 07:14 AM
UHaul door hinge keekers Problem Solving | Owners Helping Owners 10 03-05-2012 06:38 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Trillium Door Hinge in rotted wood Lise S Problem Solving | Owners Helping Owners 6 10-25-2010 06:32 PM
Door hinge Spacers Legacy Posts Problem Solving | Owners Helping Owners 0 07-11-2003 07:45 PM
