Still looking for that... - Fiberglass RV
Old 04-20-2015, 09:06 AM   #1
MisterBilliam's Avatar
Trailer: 1970l Airstream
New Mexico
Send a message via Skype™ to MisterBilliam
Hi gang- I have got a service that would be beneficial to the RV community. And would like to know how to install my service in a vendors section on here. Does anyone know where it's located?
MisterBilliam is offline   Reply With Quote
Old 04-20-2015, 09:33 AM   #2
You just sign on as a commercial member, but keep in mind that this is a Molded Fiberglass Group.
Old 04-20-2015, 09:39 AM   #3
New Mexico
Bob I did a decal replace on a Burro a while back...is that what you mean by molded fiberglass- as the outer body of it looked like two pieces joined in the center?
Old 04-20-2015, 09:50 AM   #4
Molded fiberglass, as in the body shell is usually made in two pieces vs. "Stick Built" where there may be sheet fiberglass panelswith conventional construction with lots of edges and a very square shape.
Look under the "Manufacturers" pulldown at the top of the page for typical units.
Same as comparing your Airstream to other conventional trailers. A lot in common and a lot very different, especially attitudes...LOLOLOL
Old 04-20-2015, 11:00 AM   #5
Bill, I see that you are already registered as a commercial member. To post your product or service, there is a section of the Marketplace just for vendors. Click on the Classified tab at the top (ignore the drop-down menu) and look down the list of sub-forums for Commercial Posts and Products. That's your spot!
In answer to your other question, yes, the Burro is an example of a molded fiberglass trailer. The exterior shell is formed in (usually) two large molds in the shape of the finished trailer. The pieces are then fiberglassed together to create a unitary fiberglass body, which is then set on a conventional lightweight trailer chassis. Sometimes the interior is built out in fiberglass, too (like the Burro). Others use traditional wood cabinetry inside. The main distinction between molded fiberglass and conventional construction is that the fiberglass shell is seamless and self-supporting. There is no framework of wood, aluminum, or steel inside supporting the walls and roof. It's different from framed trailers with a thin fiberglass skin.
In these parts, we think molded fiberglass is the best way to build a trailer, bar none!
Old 04-20-2015, 11:17 AM   #6
Gotta say, unless I really needed an item real bad, and couldn't find it elsewhere, I might look in those rather lengthy and somewhat dated listings. For the most part, Commercial members also start a new thread in the General Chat forum to announce products of interest to FGRV owners.
But as was earlier seen, sellers of car parts and such might not be so well received in the forums sections.
Still Looking 13 Boler/Trillium Michelle A Wanted: Molded Fiberglass Travel Trailers 3 02-01-2009 10:58 AM
Still looking for 13' boler, u-haul... New England and beyond... NancyLucier Wanted: Molded Fiberglass Travel Trailers 1 08-06-2008 04:22 PM
Still Looking - Boler 13 foot furnace Kurt in BC Classified Archives 4 03-20-2008 09:29 PM
Still looking and hoping - 17' Burro Penney H. & Mike E. Wanted: Molded Fiberglass Travel Trailers 1 10-25-2007 10:19 AM
Still looking: for Burro or Burro clone, wide body, 14' to 17' Penney H. & Mike E. Wanted: Molded Fiberglass Travel Trailers 0 08-29-2007 07:48 PM
