Stinky slinky hose brands? - Fiberglass RV
Old 02-24-2016, 08:56 AM   #1
BatDude's Avatar
Trailer: Escape
Hi all,
Earlier in our winter trip I ordered 2 RhinoFlex 5' hoses as we often need 3 to reach the connections.
The original 5' blue light weight hose that came with our new Scamp in Oct. 2014 has long since has been tossed as it was very leaky.
I replaced that one with a generic brown hose that seems to be the same light weight plastic and now it too is leaking where the metal ribs have worn holes through while riding in the front holder.
Guess I will replace this with another RhinoFlex.
Any other suggestions for a more durable hose?
I did add a rear bumper 6' plastic fence post so I can store the 2 RhinoFlex on the Scamp as per Bob and Norm's suggestions.
Cheers,
Bat Dude
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is online now   Reply With Quote
Old 02-24-2016, 10:08 AM   #2
IllAnnoy
I have found that the red Valterra hoses and accessories are the best for my money. available at Camping world and other RV shops.
Old 02-24-2016, 10:26 AM   #3
Trailer: 2008 Casita 17 SD
Not sure as to what happened to your Rhino-Flex hose, but they are probably the "Rolls-Royce's" of RV sewer hoses on the market, and generally about as "bullet-proof" as any out there. I also use these and have had excellent results with them. I have also had a few "cheapo" hoses that aren't worth carrying as well, but I soon learned that you get what you pay for, (recalling the junk "freebie" ones they give you to get you out the door,)
Old 02-24-2016, 10:41 AM   #4
Pine needles, grit and grime can puncture the best of hoses. I've seen where folks carry things from PVC gutter to pipe cut in half to lay a sewer hose on. I know camping over in Eastern Oregon in the lava beds is sure fire way to have a leaker.
Old 02-24-2016, 10:44 AM   #5
IllAnnoy
Maybe "BENTley" may be more appropriate...Or "Rolls Kenardley" since the stuff Rolls downhill and Kenardley make it up the next!
Our freebie hose actually wore through just rubbing on the inside of the carrier!
Old 02-24-2016, 10:57 AM   #6
Floyd ,which series of Valtera sewer hose are you referencing - Dominator or Viper ?
Old 02-24-2016, 11:29 AM   #7
IllAnnoy
I don't recall either name associated with the red hose, but it is the series shown above.
From what I saw in images, the Dominator is black and the Viper is grey.
It may be called "EZ Coupler".
Old 02-24-2016, 12:11 PM   #8
Trailer: 77 Scamp 13
I think the OP is saying the 2 Rhino hoses are good but the third hose needs replacing for the third time. First was OEM equipment, now the generic brown one to replace OEM hose has failed.
I only ever hooked up to drain tanks on the way out and my hoses lasted a long time. Several years as I recall. I think the OEM hoses are intended for just that level of use. Continuous use is probably much harder on them. From UV if nothing else, plus the stretch & flex into position for hookup and remaining under that stress for longer periods might also reduce lifespan of a hose.
Old 02-24-2016, 01:05 PM   #9
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I have the Viper, and it is gray. And IMHO, it is better than a Rhino. My Viper has lasted way longer than a Rhino I previously owned.
Old 02-24-2016, 01:21 PM   #10
Stinky slinky length to fit front holder?
I have the brown hose and it fits in the front holder. What brand/ size hose will fit in the front holder?
cookie_c is offline   Reply With Quote
Old 02-25-2016, 09:24 AM   #11
As to the diameter, they are all standard 3" RV sani-hoses, and will generally all fit in the standard square "sewer hose bumpers." However, that being said, there is the matter of various terminal end fittings attached to some hoses. Certain end fittings, which generally consist of the standard male and female "bayonet lug" style twist attachments, are removable, but there also exists several other types of permanently attached end fittings out there. (Actually, they are all removable, but some require tools or are a bit of an impractical ordeal to remove and reinstall, so I refer to them as "permanently attached.") Some of these fittings are the 45 degree or a 90 degree angled end fittings that may be attached to your hose. If you have these types of end fittings, and you find that they aren't the kind that just twist off the bayonet mounting lugs, then they may not fit inside those square sewer hose bumpers. Many owners have installed their own aftermarket sewer hose storage tubes, with most generally made from either square plastic fence posts or large black ABS plastic plumbing drain piping to store them in
Old 02-25-2016, 10:07 AM   #12
Trailer: Escape 2013 19 ft
Have been using the light blue presto fit for over 20 years . 2 sets , never got holes in them just replaced with new every RV changeout . Pat
LindaandPat is online now   Reply With Quote
Old 02-25-2016, 10:38 AM   #13
The issue is length of the hose when compacted
I guess I was unclear. The issue is length of the hose when compacted to fit in the stock front holder. The heavier the gauge of plastic the longer it will be when compacted. The front holder on a Scamp 2007 is really short. A few brands will tell you the compacted length but most don't. Is there a brand with the fittings pre attached the will compact to fit the Scamp front holder?
Old 02-25-2016, 10:44 AM   #14
Ralph, would you consider taking that Fugly thing off the front of your Scamp and adding a holder to the rear... under the bumper area? A number of folks have done that (in fact I think new Scamps no longer have the tube mounted on the front). There are many different methods of making a stinky slinky tube holder. You'll then have many more options and lengths of sewer hoses you can buy/use.
Where to store the stinky slinky in a Parkliner? frank_a Modifications, Alterations and Updates 70 05-31-2016 12:59 PM
where do you put the stinky slinky? Christi V. Problem Solving | Owners Helping Owners 25 08-14-2013 10:08 PM
Hose Buddy --For sewer hose Kevin K General Chat 5 12-09-2012 07:37 PM
Still stinky! Yamaha_gurl Problem Solving | Owners Helping Owners 6 07-18-2011 10:08 PM
can you mix solar system brands? Nancy H Electrical | Charging, Systems, Solar and Generators 2 06-15-2006 07:47 PM
