Stop the Bleeding! - Fiberglass RV
Old 04-18-2008, 09:05 AM   #1
So we had two sunny days recently, before winter descended on us AGAIN, and in celebration I visited my favorite TrueValue hardware store with a stub of PEX tubing in my hand. The plan was to put a damper on the jitterbugging going on under the sink from the water pump and associated piping.
Sure enough, they had rubber-cushioned clamps and pipe insulation, so I bought some.
Later, as I was doing my taxes in the Burro-office, my mind wandered off-topic AGAIN and it occurred to me that maybe this foam tubing insulation (5/8" ID and 1 1/2" OD) might multitask, especially since they now put a decent adhesive on the edges of the split.
Since we bought the trailer in 2000 I have snubbed my bald head on the top of the door frame numerous times, forgetting that it is low and dangerous if you move fast and carelessly. Blood has flowed and scabs have formed many times from me and various visitors. I even prevailed on Frederick to part with one of his rubber duckie decals and mounted it over the door as a reminder. Probably a 30% reduction in blood flow.
Turns out that the weatherstripping was the same thickness as the foam rubber. So I removed it and stuck the foam roll around the offending edge and tried the door to see if it was too thick. No, it was just right. So I cut and trimmed it, and the adhesive edges made it stay firmly in place.
So if you have a similar door (a generic RV door with inner screen door. Ugly but practical) it may be worth a try. Certainly cheap, and takes care of the worst edge on the frame. I may even clad it in some curtain material for effect.......
Old 04-18-2008, 09:51 AM   #2
Greg A's Avatar
Trailer: 2015 Escape 19
Per,
If you get the rubber type instead of the foam it is even better as a head gasket....
We had a discussion recently about using the pipe insulation for the door gasket on hard to seal Scamp doors here.
Inexpensive door gasket
I've had this in place for about 6 months. Works great and bonus is it saves the top of your head. If you need to
add adhesive the electric glue gun works great making sure the pipe insulation is glued down well.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
How to put on a door stop? vdelzen Care and Feeding of Molded Fiberglass Trailers 14 05-23-2008 04:15 PM
Truck Stop Paddy Morris Jokes, Stories & Tall Tales 2 07-23-2006 07:26 AM
Stop me Gina D. General Chat 52 02-25-2006 02:24 PM
Must stop/Addicting Legacy Posts General Chat 1 05-23-2003 03:38 PM
Pull, Steer and Stop Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 01-05-2003 11:40 AM
