Storage nightmare - Page 4 - Fiberglass RV
Old 07-06-2013, 06:24 PM   #43
Ooops' Actuially I was in H/F this morning and looked at that tire & wheel and Brian is correct, the pic had me fooled.
But the 8" tire and wheel is only about $20 and has a 4 on 4 bolt pattern/.
Old 07-06-2013, 07:24 PM   #44
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Originally Posted by Brian B-P View Post
I'm pretty sure that's 10" overall diameter (way too small), rather than 10" wheel diameter (required to clear the brake drums). A proper 10" trailer wheel is only $20.
My 8" golf cart wheels (not matched set, as they were yard sale items) fit fine on one side, and the other side needed 1/2" spacer on the studs so the wheel would not get pressed onto the brake drum.
Old 07-07-2013, 09:27 PM   #45
Roy in TO's Avatar
Sounds strange. One would think they would be the same on both sides.
Old 07-07-2013, 10:12 PM   #46
Maybe it's the "Yard Sale" wheels that are different.
Those yard sale sellers will tell you anything to move their stuff, even "Yep, it'll fit"
Old 07-07-2013, 10:23 PM   #47
David B.'s Avatar
Trailer: Lil Snoozy
It might be mismatched wheels, but then again, when I purchased our used 1990 Scamp, one side had studs, the other bolts to hold the wheels on the hubs. I added studs to replace the bolts, so the hubs probably have a slightly different shape, so the 8" wheels might be more alike, leaving only the different hubs to be the difference in fitment.
Old 07-08-2013, 02:39 PM   #48
David Tilston's Avatar
After almost losing a wheel, the studs were so damaged, they put a new brake drum on. The bolts are a different colour, but that's it.
Old 07-08-2013, 03:47 PM   #49
ShawnKK's Avatar
I bought some 8 inch wheels but never open the box. It still wount fit in my HOA garage.
I am just asking or axin. If your 8 or 10 inch wheels wont fit due to the ele brakes, can you just flip the wheel? In other words, make the outboard side inboard? Not like your going to drive it down the road.
ShawnKK is offline   Reply With Quote
Old 07-08-2013, 04:18 PM   #50
Brian B-P's Avatar
Now that's creative thinking: treat it like a dually wheel, which can be flipped to inboard (around the brakes) or outboard positions.
Unfortunately, in addition to the issue of whether or not the wheel would seat properly on the hub (I don't think it would), there is the problem that typical trailer wheels have about zero offset: the wheel would sit in about the same place even if you could flip it around.
Title Nightmare! melissab Money Matters 5 03-03-2011 06:25 PM
More storage Per Walthinsen Modifications, Alterations and Updates 12 07-27-2008 04:49 PM
Worst nightmare comes true Gina D. General Chat 24 05-11-2008 03:35 PM
RV Storage Lisa F General Chat 9 03-12-2006 04:57 PM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
