Storage nightmare - Fiberglass RV
Old 07-03-2013, 07:01 AM   #1
courtney's Avatar
Trailer: 1982 13ft Scamp purchased on May 2nd
Storage nightmare
So, I got a letter from our HOA on Friday saying I had to get our Scamp out of the driveway. We've already secured a storage unit to park it on but were keeping it out front so we could work on it daily. We're leaving for the beach tonight, so yesterday we decided to put it in the unit. It wouldn't fit! Too tall for the door!! So we resigned ourselves to take it back home, clean out one side of the garage, and put it there. Wouldn't fit there either!!! It's not that the body itself is too tall, but it's the vent. Tried letter air out of tires some, didn't help. Any ideas?
courtney is offline   Reply With Quote
Old 07-03-2013, 07:08 AM   #2
Ice-breaker's Avatar
How much too tall is it?
Ice-breaker is offline   Reply With Quote
Old 07-03-2013, 07:23 AM   #3
Brian B-P's Avatar
There are some very low profile vent lids, although I don't know if any are still in production. I saw a flat aluminum lid on a Boler that allowed it to just get under the seven foot maximum height for B.C. Ferries without paying the extra height charge. The details, of course, are important... thus Dave's question.
Old 07-03-2013, 07:27 AM   #4
_Scamp87_'s Avatar
SouthEast
I had to put mine in the backyard behind the privacy fence.
1)Is the backyard an option for you?
2)what if you run and buy a cover for it? Like in our neighborhood you can't have a vehicle without a plate....so just cover it up.
3)expanding from 2....could you put a plate from another car on it and put the car in the garage?
Sheesh what a frustrating ordeal.
_Scamp87_ is offline   Reply With Quote
Old 07-03-2013, 07:28 AM   #5
_Scamp87_'s Avatar
SouthEast
Or is it possible to phone family or a friend just until you get back?...then deal with the issue.
Old 07-03-2013, 07:55 AM   #6
courtney's Avatar
The vent is about two inches too tall. HOA says has to be behind house. We have room in side yard, but zero land behind house. Drops off. Will explore low profile vent.
Old 07-03-2013, 07:59 AM   #7
Roy in TO's Avatar
Would a 6' fence at the side with the trailer back far enough so you can't see it from the street cut it? Sounds like visibility is the issue.
Old 07-03-2013, 07:59 AM   #8
Brian B-P's Avatar
Does the vent cover come off really easily, and would that be enough (2" seems like a lot for just the vent cover)? You don't need the cover while in the storage unit or garage.
Old 07-03-2013, 08:03 AM   #9
Trailer: 1976 Trillium 1300
Check out Vintage trailer sounds like they have some that may be lower
Fan-Tastic Fan Vent
kootenaigirl is offline   Reply With Quote
Old 07-03-2013, 08:15 AM   #10
Roy in TO's Avatar
From link: "Our FanTastic vents have durable flat lids. The flat lids looks a lot more like the old flat Hehr aluminum vent lids than the more modern dome lids do. And they extend a mere 3" above the trailer roof."
Old 07-03-2013, 08:38 AM   #11
Gilda's Avatar
Trailer: 2011 Scamp 13'
Other FGRV members have said they put little wheels on their trailers for storage. Look around your neighborhood for appropriate spaces. Perhaps you could approach the owner and pay them a bit to park your trailer there. As a last resort, there are storage facilities specifically for trailers. We found a facility one hour from our home that cost 1/3 as much as in our "high-rent" town!
The Gleeful Glamper
Gilda (Jill-da)
Old 07-03-2013, 08:48 AM   #12
Trailer: 13 ft Scamp
I have the exact same problem with my HOA and clearance into our garage...my fix was really easy....I simply made the vent removable using some simple wingnut hardware it takes...if you want i can send some pics it takes about 5 minutes to put on & take off
Old 07-03-2013, 08:59 AM   #13
Gilda's Avatar
Wow! 'Looks like Alan has your answer, Courtney!
The Gleeful Glamper
Gilda (Jill-da)
Old 07-03-2013, 09:01 AM   #14
Gilda's Avatar
Alan,
Could you send photos and directions to everyone via this forum? Perhaps that solution could work for me and many others as well! What do you do to make the roof leak-proof?
The Gleeful Glamper
Gilda (Jill-da)
Old 07-03-2013, 09:04 AM   #15
I will be more than happy.... i'll try to provide a brief write up as well as some pics
It may be a day or to as I'm camping over the 4th ( go figure)
Old 07-03-2013, 09:26 AM   #16
They do still make the flat lids for the Fantastic fan. about $14-$20.
However, depending on the vent's location, I have found that I could get the vent through the overhead door by carefully raising and lowering the tongue at the right times while rolling it through the door.(As long as the vent is not directly centered over the pivot point).
Old 07-03-2013, 09:39 AM   #17
David B.'s Avatar
That's what I found I could do also (I used to remove the cover which is a PITA)
but I still am required to replace our wheels/tires to 8" golf cart wheels to fit through our 7' door.
Dave & Paula
Old 07-03-2013, 09:59 AM   #18
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
A couple of people have had success purchasing a cheap set of rims & using them without tires to fit their trailer in a garage...
Old 07-03-2013, 09:59 AM   #19
Bobbie Mayer's Avatar
is there trim at the top of the garage door? One thing I did early on with my Campster and 7 foot door was (accidentally) rip the wooden trim off. That allowed the Campster to fit in more easily and didn't make any difference to the door. Only added about half an inch though.
And I forgot to say- MOVE. I hate HOA. My sister lived in one place that required a garage for every vehicle. But did not require that the vehicle be in the garage. So they had to build a third garage space even though then they just parked the truck in the driveway with the other cars! HOA should not make rules for things that don't hurt anyone, like an RV parked on the property, visible or not.
Old 07-03-2013, 10:54 AM   #20
cpaharley2008's Avatar
Some garage doors on automatic openers can be disconnected and pushed up farther, use a support to hold up, this may give you the extra 2".
Jim
Never in doubt, often wrong
Title Nightmare! melissab Money Matters 5 03-03-2011 07:25 PM
More storage Per Walthinsen Modifications, Alterations and Updates 12 07-27-2008 04:49 PM
Worst nightmare comes true Gina D. General Chat 24 05-11-2008 03:35 PM
RV Storage Lisa F General Chat 9 03-12-2006 05:57 PM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
