Storage of Honda Generator - Page 2 - Fiberglass RV
Old 08-20-2008, 08:15 AM   #15
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
We carry our Honda 2000i in our Odssey in a plastic storage box which I have added foam weather stripping to the lid to assist in vapor control. It resides in a well at the back behind seats so shifting around is not an issue.
However, I recently built a fiberglass box on our tongue for carrying and running the generator, but have don't neither yet.
Patrick M. is offline   Reply With Quote
Old 08-20-2008, 08:17 AM   #16
Thanks Tom Trostel from DR!
We’re always discussing generator requirements for running our air conditioners and you mentioning www.arnoldservice.com and the SPP6E hard start relay could very well be the solution to most of our generator / AC problems.
I to have the McCulloch FG2000Tc and while it will start the AC, it goes into overload when the AC cycles off then back on.
I ordered the CAP and will post a follow-up report after I install it.
Old 08-20-2008, 08:46 AM   #17
Joe Z's Avatar
New River AZ
The gas cap on the "Honda2000" is great.... It has an on/off lever on the cap and what happens is when you put the cap in the "Off" Position (not running mode) it completely seals the cap so no vapors escape ...........
When you put it in the "On" Position (running mode) the cap is now vented and lets air in to run the unit.
Always travel with the cap in the "Off" Position and you will be fine
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 10-29-2008, 06:03 AM   #18
How is the box and generator attached to the trailer in the pic with generator on front? Is one side open? Concerns about theft?
Don
d_wildemann is offline   Reply With Quote
Old 10-29-2008, 07:07 AM   #19
Patrick M.'s Avatar
Here's another view. The box is bolted to the tongue frame. The generator and gas can are strapped to the box bottom, and the generator is locked to the tongue frame using a cable and padlocks. However, since cables can be cut with a bolt cutter, this method is not foolproof.
The box also has a locking top to prevent casual inspection of the contents, and when open, the front can be slide out for running the generator in-place.
generator
New Honda Generator Frances General Chat 12 06-14-2010 06:41 PM
New Honda Generator Time K Modifications, Alterations and Updates 2 07-12-2009 09:29 PM
Honda Generator For Sale Marilynn Pryor Classified Archives 3 07-05-2009 09:58 AM
Honda Generator Maintenance Patrick M. Care and Feeding of Molded Fiberglass Trailers 4 06-26-2009 08:10 AM
Honda Generator Commercial ronsmith100 General Chat 9 04-14-2009 09:56 AM
