Stored pipe of draining 3" under the caravan? - Fiberglass RV
Old 07-05-2015, 06:35 AM   #1
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
I have Bigfoot 17 1986, I cannot store the pipe of draining of 3 inches with fittings, in the rear bumper, It sticks in this one.
I believe that the last owner had problems with his storing of pipe of 3", I removed 3 sections of pipes stayed in this bumper.
Behind wheels the plumbing uses all the space.
I look to fix it under the trailer, just in front of the wheels of this one, with an easy access of the side connection.
Is my solution good?
Have a good day,
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 07-05-2015, 08:33 AM   #2
I routinely have used 4" plastic drain pipe, attached under the RV, and fitted with standard end caps, for hose storage, worked fine for me.
Old 07-05-2015, 11:28 AM   #3
I've seen plastic, or probably it's PVC, 4" square fence posts used for hose storage
Old 07-05-2015, 02:42 PM   #4
Yup, Like mine.... I actually ended up putting it under the trailer towards the rear without any grounding/clearance issues.
Old 07-06-2015, 01:33 PM   #5
Gilles's Avatar
Quebec
Finally I have installed the pipe in front of the wheels, I have no place in the back of the trailer.
I had a remaining part in composite.
I cut two pieces in this one to fix the pipe under the trailer.
As it is installed in front of the axle, I think of installing a kind of guard mud for the width of the caravan to protect better the pipe, against the objects which could pass under the caravan, as rocks, racoon, and more....
Gilles
Bigfoot 25B21RB.
Boler pipe and fittings under sink Jeannette in NS Plumbing | Systems and Fixtures 1 06-01-2015 04:13 PM
WI | SOLD 2011 Scamp 13ft, Air, Awning, Elec Brakes, Frig, Heater - LIKE NEW Stored Inside BillE Classified Archives 8 08-02-2014 01:48 PM
Curtain rods made from PVC pipe "what say you"? ShawnKK Modifications, Alterations and Updates 12 10-19-2013 07:05 PM
Convert Gray Water Pipe from 1 1/2" to 3" Chantal L. Plumbing | Systems and Fixtures 6 08-11-2011 05:22 PM
Food Stored in Camper Nita F. General Chat 8 12-11-2006 06:01 AM
