Storing 13' Scamp...I'm so confused!! - Fiberglass RV
Old 09-20-2014, 05:35 PM   #1
This is great....Read Owner's Manual and talked to 2 people at Scamp in Backus, MN and got 3 different methods for long term storage with regard to suspension.
The manual says jack up axel. The service mgr says put down the stabilizers on back bumper and jack up front tongue jack, but leave wheels on ground, and reduce tire pressure. I specifically asked him if I should jack up axel and he said no. An experienced salesman said put down rear stabilizers, and lower tongue jack until wheels just clear the ground.
Maybe I should just use a sky hook. Any suggestions and rationale welcome. Thanks.
Slim is offline   Reply With Quote
Old 09-20-2014, 05:42 PM   #2
Only because torsion axle are known to sag as they age, I'd try to take the pressure off of the suspension by lifting and blocking under the axle and/or frame.
Sadly we don't get to worry about that out here in year around RV country, AKA, the Golden State.
Old 09-20-2014, 07:35 PM   #3
DougOlson's Avatar
Jacking up the axle is no different than jacking up the tires, as far as suspension is concerned, right? To take pressure off suspension you need to jack up frame and let the axle & wheels loose. Am I missing something?
Sent from my SM-T310 using Fiberglass RV mobile app
DougOlson is offline   Reply With Quote
Old 09-20-2014, 07:44 PM   #4
I put mine up on jack stands between trips. I place two jack stands on the frame near the axles. I also deploy the stabilizers. Takes 5 minutes using a small floor jack. In addition to allowing the rubber in the axle to relax, it serves as an extra layer of theft-deterrent (combined with a coupler lock).
Old 09-20-2014, 08:01 PM   #5
The Scamp uses a Torsion Axle. A long tube with the suspension components runs across the trailer. At each end are leading or trailing arms and, at the end of each are the wheel spindles. I think that the suggestion to support it on the axle refers to the large tube that runs across the frame. It doesn't have an axle in the usual sense.
Old 09-21-2014, 12:52 AM   #6
I believe Dexter says DO NOT JACK or BLOCK the trailer on the axle. You can bend the tube and damage the axle.
I have never worried about taking pressure off the axle. I'm not sure how much difference it makes. An axle generally needs to be replaced between 15 and 30 years. Dose storing the trailer for 6 months with pressure removed change that by a lot? Hmmm.. Probable not worth the fuss and bother.
I noticed the OP was from Oregon. There's not a single month that we haven't used our Scamp in Oregon. That's one of the great things about our state, there's always someplace to camp.
Old 09-21-2014, 02:13 AM   #7
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Dennis, I don't do that as mine doesn't sit long enough to cause any undue stress...I think. I wouldn't use the stabilizers for that though as they are a friction catch and can slip over time. Just run the tongue jack down till the rear end is up an inch or two, put a couple jack stands under the frame rail just behind the axle and jack up the front till it's level. Less than five minutes and you're done. All you are looking for is taking the full weight off the axle.
On a side thought, it seems from comments here that axles need replacing around 25 - 30 years of age. Wonder how many of them sat for years with no use at all. I would think that by at least some kind of regular use that that would increase the lifetime of the axle as it's moving up and down and not static. Just my 2 cents worth.
Old 09-21-2014, 08:10 AM   #8
I always understood the point of storing on jacks was preserving the height of the axle, not so much extending its lifespan. Seems like the rubber will eventually harden and lose its resiliency regardless of whether it is blocked or not. As it ages, storing on jacks keeps it from becoming "set" in a flexed (ie, lowered) position.
If that's correct, the practice could actually mask a shot axle, since it wouldn't have the "low-rider" look. I make a point to notice movement of the down arms when I jack it up to put it on the stands.
Not sure if regular use makes a difference in axle life or not. Seems like environmental factors might also come into play. But for most of us, those are not variables over which we have much control. Wouldn't we all like to use our trailers more and have access to indoor, climate-controlled storage!!
Old 09-21-2014, 09:42 AM   #9
Dan Meyer's Avatar
For the first two or three winters, I jacked up the trailer for winter storage. I've not done it since, and after 14 years the trailer seems to be sitting on the suspension just as high as it did on day one.
Whatever you do, do not do as the salesman suggests. The stabilizer jacks are not designed to carry the weight of the trailer. If you choose to take the weight off the axle for the winter, use a jack to lift the frame near the axle, and then place a jack stand under the frame.
-- Dan Meyer
Old 09-21-2014, 12:30 PM   #10
My Scamp's old paper manual says the same
I am with the others - there is no way the rear jacks are designed to jack up the trailer to the point the tires are off the ground either. I think my manual may address that as well.
I did notice though in the newer manuals or on the on line video one last year - don't remember which, that Scamp does say you can use the rear stands and jack up the front jack just enough to take a bit of pressure off the axle for storage.
Old 09-22-2014, 11:58 AM   #11
Thanks everyone for the good information. Definitely won't be jacking up axle or hanging unit from back stablilzers.
Old 09-22-2014, 12:27 PM   #12
Does your manual actually say jack up axel? or does it say something like mine does under Service and Maintenance:
" Jacking up the trailer: On the trailer there are two min beams made out of 3 inch by 1 ˝ inch tubing, one on each side. Either of these can be used as a point to jack up the trailer. Jack should be placed close to the axle or toward the rear of the trailer, so that the whole weight of the trailer is not on one point. WARNING: The rear bumper jacks are not intended to be used as a jack for changing tires. A scissor jack, hydraulic jack, or a floor jack should be used."
Under Winterizing it does though reads in part: "Running gear: Jack up the axle and block it up to take the weight off the suspension. Leaving the weight of the trailer on the suspension for extended periods while stored is extremely hard on the torsion axle. The rubber tends to compress and not relax as fully as before. Relive tire pressure to 10-15 pounds while stored. This extends tire life."
I don't believe under the winterizing section that they meant the "Jack up the axle" statement to be taken literally and that people would follow the instructions under service and maintenance as to how to jack up the trailer.
Old 09-22-2014, 01:33 PM   #13
Mine says what yours says.
Old 09-24-2014, 09:42 AM   #14
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Yuppers on not jacking the axle like others have stated and definitely not utilizing the rear-stabilizers to lift/take weight off.
On a friendly ramble...as Byron hinted...
since i'm in Oregon also i'll say take it out to somewhere fun once a month if at all possible... there are plenty of nice spots in our _neighborhood_ year round to have a night or two away from the hustle of daily life. We do not block up our TT or winterize it in any way and it's always just a hitch away from adventure. We typically do our best to plan a Monday>Friday adventure every 5 to 6 weeks with only November/December (our crazy "Holiday" season at work) as down time. Even then we'll take the van-alone out for a night or two.
Cheers,
Thom
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Storing scamp JoniS Modifications, Alterations and Updates 2 05-22-2013 06:47 PM
First Time Storing of Scamp barryra General Chat 3 08-24-2010 09:08 PM
Storing Awning Pole Carol H Modifications, Alterations and Updates 5 04-30-2009 11:09 PM
Pantry organization- how are you storing your food? Bobbie Mayer Problem Solving | Owners Helping Owners 15 04-30-2008 03:38 PM
Storing security Quint General Chat 4 01-16-2006 09:27 PM
