Stove hot while fridge on - Fiberglass RV
Old 08-06-2014, 04:38 PM   #1
morgynm's Avatar
Nova Scotia
I pulled up my big girl pants and tested the propane system today. That I'm writing this is a good indication that I didn't blow myself up! Yay me!!
One thing I noticed was that the right burner in the stove was extremely hot after a while. I kept checking that I had turned that burner off. The fridge was running off of propane at the time so maybe that's normal??
Is there supposed to be a shut off between the stove and the tank somewhere? Or does the propane for the stove run through the lines for the fridge?
Morgyn
1981 13' Boler
Nova Scotia
morgynm is offline   Reply With Quote
Old 08-06-2014, 04:46 PM   #2
David Tilston's Avatar
I am more familiar with Trilliums, but there is not too much difference. When running on propane, the fridge has a small flame, and a chimney that comes up to the bottom of the stove. The fact that the stove gets hot is not surprising. But, does the fridge get cold?
Old 08-06-2014, 04:54 PM   #3
morgynm's Avatar
Nova Scotia
The fridge seemed to get colder. The freezer was, well, freezing at least! I'm still trying to figure out the temp knobs for it as I'm not sure where the indicator was to show the temp setting.
Morgyn
1981 13' Boler
Nova Scotia
Old 08-06-2014, 05:06 PM   #4
There is a shut off on the propane bottle and usually it's the only shut off in the trailer. If you have an oven the heat comes out the top back part of the stove. Even the pilot generates some heat. Could this be your issue ? An absorption refrigerator produces heat and it has to go some place, usually a vent on the roof or side of the trailer. I would check the vent on the refer to make sure it is not blocked. A insect or birds nest could be the culprit. If the stove, oven and pilot light are off the stove should be cool.
Old 08-06-2014, 05:28 PM   #5
Noreen Bradshaw's Avatar
Trailer: 1981 4500 Trillium
I have a Trillium but the frig is below the stove top. When the frig is on propane, there is heat coming up through the stove top. Not too hot to touch but warm enough to notice.
Noreen Bradshaw is offline   Reply With Quote
Old 08-06-2014, 05:37 PM   #6
cpaharley2008's Avatar
Pictures of your set up may help, we love pictures here.
Jim
Never in doubt, often wrong
Old 08-06-2014, 06:33 PM   #7
Trailer: 77 Scamp 13
Propane fridge has a burner and is moving heat from inside the fridge to the coils on the back to be vented to the outside. Refrigerators don't make cold they move heat.
In this case to a space behind the fridge and probably right under your stove. Heat rises, stove gets warm.
There should be some sort of vent panel in the outside wall behind the fridge so the heat can escape but the temperature in that space can get pretty warm. Suggest getting one of those inexpensive fridge thermometers so you can figure out what the number settings on the dial mean in terms of food storage temp.
Some people end up using a 12 volt computer fan with a switch mounted to blow air through the outside vent to help remove the heat, cooler it is behind the fridge the better they work.
The fridge also works better if it has more stuff in it, especially if pre-chilled before loading, does take a fair amount of time to get cold. One other thing if it gets really hot outside (or in the space behind the fridge) the inside temp will not stay as cool. So you might be able to keep ice cream in freezer at 70 degrees but not at 95 degrees of outside temp.
Old 08-06-2014, 06:59 PM   #8
CampyTime's Avatar
Trailer: Scamp 13' Standard
The propane lines do not get hot when raw propane runs through to be burned. That's not your problem. My first thoughts were either a pilot heating that area up or poor/inadequate venting. The pilot sits much lower than your stovetop, way down in access door area. I'm wondering if vent could be occluded or damaged in some way as upper vent in outside of trailer is about stove height. Fridge generates a lot if heat while running.
Maybe others wi chime in with their thoughts. How old is your trailer and what make?
Old 08-06-2014, 07:07 PM   #9
Morgyn
1981 13' Boler
Nova Scotia
To me this is a pretty scary situation. My Scamp has never had the stove get warm when fridge is running. I suggest you turn the fridge off immediately, close the valve on the propane tank and take the trailer to a certified propane person to check it out. It's possible that you have a parcial blockage of the fridge burner, which could cause flames at the air intake for burner. Not good.
Old 08-06-2014, 07:44 PM   #10
morgynm's Avatar
Nova Scotia
This is what the back looks like. The propane valve for the fridge was screwed into the open position...which I assumed was the closed position because, at least in my mind, who would want that valve permanently open?
Name:	ImageUploadedByFiberglass RV1407375728.108950.jpg
And my old Coleman stovetop...
Name:	ImageUploadedByFiberglass RV1407375766.428464.jpg
Not that those might help much.
Morgyn
1981 13' Boler
Nova Scotia
Old 08-06-2014, 07:56 PM   #11
morgynm's Avatar
Nova Scotia
And there's this odd propane pipe under the sink that appears to eventually lead to the stove. Click image for larger version
Name:	ImageUploadedByFiberglass RV1407376524.768340.jpg
Morgyn
1981 13' Boler
Nova Scotia
Old 08-06-2014, 07:58 PM   #12
morgynm's Avatar
Nova Scotia
Do RV places do that type of work? I have no idea even what to google to find someone around here to work on rv propane!!
Morgyn
1981 13' Boler
Nova Scotia
Old 08-06-2014, 08:00 PM   #13
morgynm's Avatar
Nova Scotia
Sorry btw... I love my tech stuff but I can't figure out how to quote someone from the iPhone app.
Morgyn
1981 13' Boler
Nova Scotia
Old 08-07-2014, 06:01 PM   #14
morgynm's Avatar
Nova Scotia
So here's my latest wtf head shake!
Name:	ImageUploadedByFiberglass RV1407455625.581551.jpg
I pulled all the interior of the cupboards out to get a better look at what was going on in there.
Anyone know what that terminated metal tube was for? I'm wondering if there was a water heater at some point as I can also see the remains of something round to the outside that must have been fiberglassed over.
Name:	ImageUploadedByFiberglass RV1407455813.596694.jpg
Hitch goes on the car next week and then she goes in for her safety. Then she stays at the rv place for a propane and electrical checkup.
To cheer myself up, I added these lights I found in my camping bin.
Name:	ImageUploadedByFiberglass RV1407456051.081535.jpg
Morgyn
1981 13' Boler
Nova Scotia
fridge
Hot Hot Hot!!!!! Steve Hammel General Chat 7 06-10-2013 06:40 PM
but what if its hot & sticky while boondocking? deryk Problem Solving | Owners Helping Owners 35 01-22-2013 09:28 PM
Get 'em while they're HOT! Buck62 General Chat 10 04-09-2007 05:32 PM
