stove problems - Fiberglass RV
Old 04-09-2013, 02:46 PM   #1
Trailer: 1971 hunter compact jr
stove problems
Ok I went to fire my stove up in my compact jr. Cause I haven't messed with it since I bought it cause the po told me it had a leak somewhere soooo... I put some gas on it and it did have a huge leak...in the control knob for the pilot light gas just blows out.. its a three burner traveler with an oven... I had another older four burner wedgewood I put it in and it did the samething gas just blows out the control knob for the pilot light...so I went to tank and it has a high pressuare regulater on it ...ain't I suppose to be low preaaure? Or could I have the regulater turned up to high but even when I turned it down gas still came out of the control
frankie is offline   Reply With Quote
Old 04-09-2013, 03:28 PM   #2
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
You need a low pressure regulator for a stove-top. If it's the original regulator-should be replaced anyway.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 04-09-2013, 03:37 PM   #3
Its a new regulator someone else put it on there I just so happened to look at it and it said high pressure on it... thank u for the reply
Old 04-09-2013, 04:45 PM   #4
Propane regulators for RV are usually dual stage. I suspect the high pressure marking is indicating where the high pressure line is connected. That's where the hose from the tank should be connected. If the propane system hasn't been used for a while it may take a bit to get the line purged of air and everything working properly. Sometimes I have to hold a light on at the burner for a couple minutes before the burner takes off.
Most RV cook tops don't have a pilot light.
If it was really leaking gas you'd smell it.
I would suggest that you take it to an RV shop to check out.
WHAT EVER YOU DO DON'T MESS WITH THE REGULATOR SETTINGS.
SMEV stove/sink combo eBay seller problems RogerH General Chat 10 05-17-2009 10:55 AM
Jackstand and stove problems gail todd Problem Solving | Owners Helping Owners 12 06-16-2007 11:41 AM
SMEV stove/sink combo eBay seller problems Chris B Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
