Stove Propane Possible Leak - Page 2 - Fiberglass RV
Old 07-07-2013, 08:13 AM   #15
Trailer: Bigfoot 1981 Trailer
Originally Posted by Otters View Post
Hi Jim. Which fridge did you buy?
Dometic RM 2354
Old 07-07-2013, 08:20 AM   #16
Now the new fridge does not cool.
Brought it home from the RV dealer and it worked fine on 110, but the exhaust stack was hot, even though it was not operating on propane. It was about 3 C (just above freezing) for awhile and then all of a sudden it popped up to 40C (over 100F) I turned it off and then restarted and the temp came back to 18C which is about 70F. I tried different settings on the thermostat, but the temp does not come down. Any ideas before I take it back to the dealer on Monday, the day before I am volunteering for a music fest, which I may not be able to attend if the fridge is not working.
Old 07-07-2013, 10:31 AM   #17
Update: Took the fridge off auto setting and disconnected the 110 and now using only propane. The temps are coming back to where they should be...hope it holds.
Old 07-07-2013, 10:45 AM   #18
Do you have a wireless indoor outdoor thermometer you could put inside it to see what's really going on with the temperature?
Old 07-07-2013, 01:37 PM   #19
As a backup, Take along a good cooler filled with ice and attend the music fest.
Old 07-07-2013, 01:43 PM   #20
Roy in TO's Avatar
The Dometic is even a 3 way fridge, although I do not plan to use the 12 volt as it draws too much power.
The 12V is nice to have when powered by the tow vehicle on those long hauls in the heat.
Old 07-07-2013, 02:35 PM   #21
Thanks for the messages: I did think of putting a wireless thermometer in the fridge, and now able to monitor it without opening it up and good idea about taking a cooler full of ice as well. I never thought of putting the fridge on 12 v but may do it. Would this not draw the battery down even whle towing. Thanks, Jim
Old 07-07-2013, 03:15 PM   #22
Brian B-P's Avatar
Not as long as the wire from the tow vehicle supplies at least as much current as the refrigerator uses.
Old 07-07-2013, 03:16 PM   #23
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You need a large wire to pull off running the fridge plus charging trailer battery - at least 10 gauge, 6 or 8 is better.
propane
How do i find a VERY slow propane leak? Mouse Problem Solving | Owners Helping Owners 37 03-22-2012 06:31 PM
Are there any 9V battery propane leak alarms? bcomnes Problem Solving | Owners Helping Owners 6 01-16-2010 07:17 AM
Propane leak? Carol Crawley Problem Solving | Owners Helping Owners 6 05-10-2008 10:29 AM
Propane leak? Kate Carney Problem Solving | Owners Helping Owners 3 07-30-2007 07:34 AM
Propane Leak Legacy Posts Problem Solving | Owners Helping Owners 13 04-24-2003 05:26 PM
