Stripped Screw Holes - Fiberglass RV
Old 03-07-2012, 05:20 PM   #1
Quint362's Avatar
Trailer: Hunter Compact ii
Kentucky
Hello all, well this week's chin rubber is stripped screw holes. My lower cabinet has two stripped screw holes but more than that the hinge is placed right at a section were it looks like two pieces of wood were glued together. I would also glue the wood as well but I have nothing to anchor to.
Not sure if I should try and screw the left side wood to the right or just fill the s crew holes with wood glue. Please I need your advice.
Thank You
Quint362 is offline   Reply With Quote
Old 03-07-2012, 05:27 PM   #2
cpaharley2008's Avatar
have you tried toothpicks?
Old 03-07-2012, 05:36 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Yea, toothpicks or wooden match sticks, mixed with a little wood glue usually works for me.
Old 03-07-2012, 06:14 PM   #4
Quint362's Avatar
Kentucky
Have not yet tried tooth picks. I wanted to try and fix the separation between the two pieces of wood. If I can stabilize the outer piece of wood I think I can find a screw to hold. At this point when I try to put the screws in the left wood just opens more.
Old 03-07-2012, 06:17 PM   #5
Thomas G.'s Avatar
Can you squirt some glue between the two boards and then drive a couple of small screws perpendicular to the stripped holes?
Old 03-07-2012, 06:18 PM   #6
put some glue and then nail the trim board from the side. let dry and fill the holes and try drilling a small pilot hole to keep from splitting the wood. Also try finer thread screws.
Old 03-07-2012, 07:00 PM   #7
Thomas G.'s Avatar
I'm no fan of nails. When the wood dries, they pull out, especially in a rockin' and rollin' trailer.
Old 03-07-2012, 07:58 PM   #8
Trailer: 1989 Bigfoot
There are hinges that will rap around and attach to the inner surface ,this kind may work for you . I think Mike Whitney on his 88 little bigfoot used piano hinge could work also ,but you will still have to repair the cabinet
How this helps
ken h is offline   Reply With Quote
Old 03-08-2012, 06:41 AM   #9
Trailer: scamp 13
ok ,,,if that strip was glued on there originaly heres what you have to do.
with a knife blade or putty knife would be better. work it into the crack and down forcing the piece apart until it is seperated. then clean off the glue on both sides by scraper or sand papre down to clean wood. you can then glue it back into place. you need to do this because its called "wood glue".......not glue glue.
thento glue it back in place, evenly coat both pieces with elmers, or your favorite wood glue. place it in position. i would then tack it in place with a couple small finish nails so it won't slide. if you don't like the nails, leave the head up so you can remove them later.
using a couple of bar clamp that can be reversed apply firm even preasure by pressing acrossed the cupboard. you want it firm,, but not so tight it squeezes out all the glue.
if you don't have such bar clamps, you can use a couple scrap sticks of wood cut slightly longer then the gap, so they can be wedged in snugly.
leave space for a scrap of wood under the ends of the sticks to protect the cabinet.
Old 03-08-2012, 06:45 AM   #10
Trailer: scamp 13
that was a lot of writing,,,but it really will only take ten or fifteen minutes do do the repair correctly once you collect you tools.<_<
Old 03-08-2012, 09:42 AM   #11
Raz
Raz's Avatar
Vermont
The method John describes is exactly how I would do it. I would use four or five 1" brads instead of finishing nail and I would use my drill to spin them partially in as if they were a drill bit and then tap and set them in the rest of the way. Like John says, 10-15 min. Once the spit is repaired ( 24hrs drying time) I would drill out the screw holes, fill the holes with a dowel (glued), softwood if you can find it. Cut flush. Drill pilot holes and reinstall your hinge. Good luck, Raz
Old 03-08-2012, 10:30 AM   #12
Trailer: scamp 13
good idea on plug and drill. though once its glued up, the original holes might be just right again. a quick test fit will tell.
Old 03-12-2012, 10:01 AM   #13
Quint362's Avatar
Kentucky
Thank you again for all responses. This is how I made the repairs. First when I tried the putty knife the wood acted as if it did not want to come off clean. So I nailed two finishing nails and filled the holes with wood glue. Waited three days and screwed the screws back into holes. Slightly slanting them so that they could "bite" into fresh wood. Installed new barrel hinge for a snug fit and all is good to go. THANKS
Old 03-12-2012, 01:35 PM   #14
Trailer: scamp 13
cool!
Screw holes? pindraak Problem Solving | Owners Helping Owners 70 06-19-2012 11:59 AM
Removing Roof Rack and Patching Screw Holes in the Roof Roger M Modifications, Alterations and Updates 4 02-08-2012 10:40 AM
what screw are used on closet,seats etc thenoob Problem Solving | Owners Helping Owners 2 01-29-2011 07:04 PM
Dress up Ugly Screw Heads Highway68 Care and Feeding of Molded Fiberglass Trailers 13 11-16-2009 05:38 AM
stripped and striped casita Legacy Posts Modifications, Alterations and Updates 17 02-24-2003 06:49 AM
