Suburban GT6-3A furnace help, please. - Page 2 - Fiberglass RV
Old 10-18-2010, 03:48 PM   #15
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Smile
yes, that is right. I still had the old burner in my furnace.
However, it seems to me that you may be able to find a burner if you can find the reference in your earlier post, or else through Suburban or a parts manufacturer. If not, you could quite possibly install your own barbecue burner if it would fit in the space. They should be just as durable as the original steel ones.
On my furnace, the orifice for the burner was mounted in the floor of the furnace chamber, with the burner mounted above it, as in the picture in my earlier post. The burner itself is just a hollow shaped tube with holes in it to spread the flame around. There is no reason why it should be any particular shape or size, within the limits of your furnace chamber. Just don't let it get too close to a wall so a hot spot does not develop.
I imagine that RV water heaters also have burners that might fit in your furnace.
I am sure it would be preferable to find one that is the same shape as the old one, however if you can't then I would explore the possibility of buying something else and making it fit.
Good luck,
Rick
Rick G is offline   Reply With Quote
Old 06-22-2012, 10:08 PM   #16
gaz
Trailer: 73 boler
I went to a place in Calgary called Alberts controls and replaced my Gas valve it not the exact same but it fit and works even Cycles on and off.
gaz is offline   Reply With Quote
furnace
77 Boler Suburban furnace help Michael Collins Problem Solving | Owners Helping Owners 11 03-26-2010 12:14 PM
2005 Scamp 13' suburban furnace Jeff Larsen Problem Solving | Owners Helping Owners 2 08-17-2009 09:27 PM
Suburban Furnace in operation kevin61 Problem Solving | Owners Helping Owners 0 05-20-2009 11:47 AM
Suburban furnace out/Olympian Wave 3 Cat In? johnsoba Problem Solving | Owners Helping Owners 3 04-20-2009 08:53 PM
suburban furnace repair. (B1700) Herb P Care and Feeding of Molded Fiberglass Trailers 11 08-26-2007 04:45 PM
