Suburban heater - Gas valve question - Fiberglass RV
Old 02-15-2010, 09:56 PM   #1
Trailer: 95 13 ft Scamp
1995 scamp 13'... Ive got power to the 2 gas valves but no gas is passing through them. I unhooked the gas line, ran 12v to the valves, and hooked up some 5/8" heater hose to the gas inlet, and blew in the hose... Couldnt push any air through the valves either. Both valve "click" on when 12v is applied, but they must not be opening.
Could the valves be bad? Could there be blockage on the heater side of the valves, causing this problem? Thanks
Todd Russ is offline   Reply With Quote
Old 02-17-2010, 09:10 AM   #2
Harry Young's Avatar
Post
Todd.
I am going to guess that you have an NT series heater, the valves need to be tested individually, when moisture gets in one valve it often corrodes that one shut, (water reacts with the aluminum body) it does require pressure to operate them as well properly. (10 inches of water column)
If the doc center is up... I sent the complete service manual there for all to use, it does cover the whole testing protocol, if the Doc center still has the flu I can send the manual to your email.
P.M. (personal message function on this site) me the model number please if you request this, post your email to me in the p.m. and I will email you the pdf.
I also have extra valves all over the shop.
Happy Camping, Safe Trails.
Harry
propane
Suburban hot water heater anode difficult to install Steve M. Problem Solving | Owners Helping Owners 7 05-25-2009 07:22 PM
LP Gas Valve Help!! for an old Suburban convection David Jack Problem Solving | Owners Helping Owners 6 02-15-2009 09:30 PM
Suburban Heater...What am I missing??? Steve B Problem Solving | Owners Helping Owners 8 01-01-2009 09:51 AM
SUBURBAN sw6p WATER HEATER gary g Classified Archives 0 07-06-2008 08:08 PM
Water heater trouble shooting (Suburban 6 gallon) Legacy Posts Problem Solving | Owners Helping Owners 12 02-14-2003 11:06 AM
