Suggestions for leveling the trailer - Fiberglass RV
Old 12-28-2015, 06:34 PM   #1
Trailer: 2011 Casita SD 17
I just bought a Scamp 13' and have been going crazy on Amazon with accessories. So fun. There is a BAL leveler for single axle trailers. It looks like a black U that slips around the tire. The Amazon comments are mostly about tent trailers but it looks like it would be good for the Scamp. It is to use instead of blocks of wood, etc.
What do you think? Have you tried one?
SactoWendy is offline   Reply With Quote
Old 12-28-2015, 07:08 PM   #2
Oh my stars Wendy, you've opened a can of worms! You are going to get lots of opinions... and I have mine
I've owed the BAL leveler for years. Used it a LOT with my Scamp. I'm a single traveler, no one to help me with backing onto blocks (or pulling forward). I just picked the spot I wanted (where's the door?), unhooked and used the BAL to level side to side. NIRVANA.
Now I have a tandem axle trailer. Same situation... single, don't want to haul a bunch of stuff. Now I have TWO BAL levelers. Still works as needed and I couldn't be happier.
Folks will say they're heavy and greasy. Heavy is subjective and if the BAL levelers are greasy... something is wrong.
Your choice. Whatever you come up with and decide, I hope it works for you.
I'm happy with my decision
Old 12-28-2015, 08:00 PM   #3
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
Wendy,
I'm another BAL convert from the blocks of wood days. I love it and my wife even more so since she formerly had to try to help me back on to just the right number of blocks. The BAL is so simple to use and a great improvement over the blocks. See my earlier post with photos of the simple system I rigged to eliminate the grease issue. BTW, we also are in a 13'er. Go for it - you won't regret it.
WDavidG is offline   Reply With Quote
Old 12-28-2015, 08:08 PM   #4
Cathi's Avatar
POBox 1267, Denison, Texas
We use stackable blocks and they are also used under the stabilizers and tongue.
Old 12-28-2015, 10:06 PM   #5
Lego-type interlocking blocks have been enough for me: inexpensive, lightweight, compact, and adaptable to other uses (like leveling a picnic table). I've never needed an assistant to get up on them. You have to buy chocks separately.
However, the BAL is very convenient to use and serves as a chock as well as a leveler; the downside is storage in a small trailer. Someone suggested a pizza delivery bag is the perfect size to store a dirty BAL in your clean trailer.
Another option with some proponents here is the Anderson leveler. Compact and convenient to use, more adjustability than blocks, includes chock, but limited lifting range.
Old 12-29-2015, 05:56 AM   #6
Connecticut
Hey Wendy,
I have a BAL leveler, which I use on a 17 ft. Casita. Overall I am satisfied with it but decided to go with the Andersen levelers. I would say the BAL is on the heavy side and because of it's size and shape a little cumbersome to use and store. I had to spread the arms of my unit in order for it to fit under my tires. I also found depending on the ground surface( grass, gravel or sand ) it can be difficult to get around your tire or more of an issue, getting it out once you're ready to break camp. Hope that helps.
wwig is offline   Reply With Quote
Old 12-29-2015, 06:14 AM   #7
GregandTeresa's Avatar
Trailer: 2016 Escape 19
I got a good deal on the Andersen leveler that Jon mentions above right before Christmas. I had narrowed it down to either the BAL or the Andersen, and decided to try the Andersen first since it was cheaper, and seems so much better/easier than the legos. Hopefully I will be happy with it, but if not, will then spring for the BAL.
GregandTeresa is offline   Reply With Quote
Old 12-29-2015, 07:22 AM   #8
Lots of old threads:
Self Leveling Wheel Chocks
Leveling a Scamp When Camping
Leveling blocks? Size & how many?
A really long (and somewhat contentious) one:
Why not just level with a jack?
Last, some general information about leveling and stabilizing:
Stablizing/Leveling Trailer While Camping
Old 12-29-2015, 08:37 AM   #9
I have the Andersen and like it very much, fast, compact, easy to use and store and the wife likes it. The Andersen coupled with a large level mounted to the front belly band make a perfect one person leveling job.
larryf is offline   Reply With Quote
Old 12-29-2015, 08:43 AM   #10
jon carpenter's Avatar
Trailer: 2012 Casita 17' SD
Illinois
We used blocks of wood to level out Casita and then tried the Anderson. Leveliing went from minutes to just seconds. Love the simplicity of the unit.
jon
jon carpenter is offline   Reply With Quote
Old 12-29-2015, 08:44 AM   #11
Leveling blocks
I am also traveling solo and am using the interlocking blocks. They are neon orange so easy to see and back onto or pull forward. My scamp 16 has levels on the side and front so that helps me find level. They are in a zipper bag so stow well.
Have not heard of the Baltimore levelers... will ck them out. This is my maiden voyage... so checking all things out.
Teal is offline   Reply With Quote
Old 12-29-2015, 08:53 AM   #12
My concern regarding using the Anderson levelers without a spotter is what might happen if you overshoot and run off the back... I vaguely recall a post in which someone did exactly that and it flipped up and got wedged somewhere. Anybody willing to admit doing that? Any consequences other than a bump at the end?
Old 12-29-2015, 08:59 AM   #13
Yes, I have done that a couple of times and had no problems (yet)
Old 12-29-2015, 09:00 AM   #14
Originally Posted by Teal View Post
...Have not heard of the Baltimore levelers...
I'm not sure what BAL stands for, but the BAL R.V. Products Group is based in Indiana.
Leveling a Tandem Trailer Jane P. Problem Solving | Owners Helping Owners 15 10-22-2017 07:15 PM
Stablizing/Leveling Trailer While Camping HAPPYSCAMPER76 Problem Solving | Owners Helping Owners 39 11-29-2015 11:00 PM
Leveling and stabilizing Dave M Towing, Hitching, Axles and Running Gear 20 06-25-2006 08:56 PM
Leveling a trialer Legacy Posts Problem Solving | Owners Helping Owners 9 06-12-2003 10:21 PM
Leveling your trailer Legacy Posts Care and Feeding of Molded Fiberglass Trailers 23 11-10-2002 05:17 PM
