Surf Side Door - Fiberglass RV
Old 10-29-2007, 07:41 PM   #1
Timmy G's Avatar
Trailer: TM14 Surfside
I have pondered the reason why my trailer door doesn't fit squarely in the hole provided for the past few years. I have never done anything about it since it doesn't leak, but aesthetically it is a bit unpleasing to look at. I have read all the fixes in this forum and have thought about warping the door to seal the spaces and trimming it to square it up, then it occurred to me ...
A few years back, I separated the body from the frame to take care of some frame issues. I remember there being some 1/2 inch plywood shims between the frame and the body forward of the door on both sides of the frame. I never did put them back in. The door currently fits with the top forward portion about 1/8 inch from edge of the door frame and the bottom about 3/4 inch. It seems to me that if I raised the front door-side corner of the trailer that the door would fit better as it would apply a wee bit of torque to the body of the trailer ... I'm thinking maybe that's what the shims were doing.
So my question is, do any other Surf-sides out there have shims between the frame and body forward of the door? I might have to play with this to see if my logic is right or if I'm just engaging in some wishful thinking.
Tim
Timmy G is offline   Reply With Quote
Old 10-29-2007, 08:07 PM   #2
Alf S.'s Avatar
Hi: My question would be... Did the door fit better before the "Out of Body Experience"??? The 1/2" shims would possibly have lifted and separated the door frame even more than now!!!
Old 10-30-2007, 05:22 AM   #3
theresa shaw's Avatar
Trailer: 1977 Surfside
Ours has the same problem, the previous owner tried to get it fixed. It doesnt bother me, but my nieghbor noticed it, and I'd like to get it fixed too!
theresa shaw is offline   Reply With Quote
Old 10-30-2007, 05:30 AM   #4
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I think you're on to something with respect to the body shims. Perhaps it was shimmed new and then the doors were installed.
I know that it's fairly easy to torque the frame and body on my Casita if I crank on the rear stabilizers too much. If I do that, the door doesn't always latch right. A ladder style frame doesn't have much torsional stiffness. Nor does the body for that matter.
As for a fix short of reinserting the shims I don't have any advice. Of course, it would be aggravating to go through the trouble of putting them back and find you still have the door alignment problem.
I suppose my only suggestion would be that if you return to the plywood shim you might try finding some marine plywood for its weather resistance. Another thought is that sometimes you can find a cheap poly cutting board that's about 1/2" thick and cut it up with normal woodworking tools for shims.
Without adult supervision...
Also,
Old 10-30-2007, 10:47 AM   #5
Timmy G's Avatar
Steve ... hmmmm ... not sure ...
Alf ... thanks for the advice, good suggestions
Theresa ... I'll play with it today and let you know if it worked ... it's only two bolts that I have contend with.
Old 02-06-2008, 05:07 PM   #6
Shelley's Avatar
Trailer: 1977 Triple E Surfside
My door also doesn't fit quite right - would love to know how you solve the problem!
Shelley is offline   Reply With Quote
Old 02-17-2011, 06:28 PM   #7
GuyB's Avatar
Trailer: 1979 Triple E Surfside
Improving door fit due to body sag
i have a surfside that had gapping,mostly at the bottom of the door
I just built the trailer out to the door and added new door hinges
pics are posted in the link
GuyB is offline   Reply With Quote
Surf Side Door Latch Alan P. Problem Solving | Owners Helping Owners 9 02-14-2010 03:22 AM
Surf Side screen door Jason, M Problem Solving | Owners Helping Owners 6 09-22-2008 08:54 PM
1977 Surf-Side TM-14 Craig Broughton Classified Archives 2 08-06-2008 10:31 PM
Surf Side Manual Jason, M Care and Feeding of Molded Fiberglass Trailers 2 07-02-2008 08:49 PM
1977 Surf-Side TM-14 Craig Broughton Classified Archives 0 05-03-2008 11:53 PM
