Surf Side screen door - Fiberglass RV
Old 09-14-2008, 01:20 PM   #1
Trailer: Surfside
Hi all,
Anyone have tips/ideas on creating a screen door for a Surf Side? I have seen pictures of Bolers with them and someone mentioned a template they got off this site, but I can't track anything with the search button.
Thanks heaps
Jason
Jason, M is offline   Reply With Quote
Old 09-14-2008, 01:49 PM   #2
Here's one I posted: Gord's Trillium Screen Door
Here's another topic, where the door doesn't require a frame: bug off screen door
Old 09-16-2008, 06:27 AM   #3
james kent's Avatar
Trailer: Boler 1984
I looked at Gords and others at a gathering and then used this rough idea to make this one.
Go to the help centre at bolerama and there are two variations of a screen door that you can make.
Just a helpful hint... first level your trailer, or the door may not end up square.
http://www.geocities.com/bolerama/helpcentre.html
Old 09-16-2008, 07:05 AM   #4
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I made a soft one that snaps on at the top and just hangs in the opening. sewed in a metal rod at the bottom to weigh it down and keep it flat. it's not 100% bug proof but it was a LOT cheaper that a hard door. I'll try to remember to snap a couple photos for you this week.
Hi all,
Thanks heaps
Jason
Scott S. is offline   Reply With Quote
Old 09-16-2008, 09:04 AM   #5
Carolyn Patterson's Avatar
Trailer: 16 ft U-Haul VT / 2004 GMC Safari
Jason,
A Uhaul trailer's screen door is very simple.
It's a thick net 'screen' with a zipper velcro'd to the wall surrounding the door. That's the way they came. Mine is an 85, been thru several renters in it's early days of existance and still going strong! If you're interested to see it, send me a PM and I can email you some pics.
Carolyn Patterson is offline   Reply With Quote
Old 09-21-2008, 12:16 PM   #6
April Wilcox's Avatar
Trailer: 13 ft Scamp 1983
That sounds like something you could easily build, using one of the $9.99 ez up screens that I just found online...
http://www.westmarine.com/webapp/wcs...;ci_sku=249627
cut out one of the zipper sides to fit the inside of your door, add some velcro*to*the*sides*to hold it*up and voila! instant screen door that you can remove easily, like the uhaul screen! I think the way we plan to set up our ez up screen shelter, we will need only 3 sides to be solid, then the 4th side that would be against the trailer can be cut, using the section in the middle w/ the zipper to cover the door, and then*some how attach the 2 cut sides of the big ez up screen to the camper (velcro maybe?) Sounds easy enough in theory.*
*I will give it a go, and see how it works out. I already have the screen ordered, and if it looks good, I might go ahead and order a few extras. At that price, if I mess it up the first try, it's got 2 sides with zippers, so I can afford to make mistakes with this project!
Thanks for the ideas!
April Wilcox is offline   Reply With Quote
Old 09-22-2008, 08:54 PM   #7
Scott S.'s Avatar
Manitoba
here's the snap-on method. as I said, not 100% bug proof so I'm making one with a zipper like Carolyn's next.
Surf Side Door Timmy G Problem Solving | Owners Helping Owners 6 02-17-2011 05:28 PM
Surf Side Door Latch Alan P. Problem Solving | Owners Helping Owners 9 02-14-2010 02:22 AM
1977 Surf-Side TM-14 Craig Broughton Classified Archives 2 08-06-2008 10:31 PM
Surf Side Manual Jason, M Care and Feeding of Molded Fiberglass Trailers 2 07-02-2008 08:49 PM
1977 Surf-Side TM-14 Craig Broughton Classified Archives 0 05-03-2008 11:53 PM
