Surfside (TM-14) Rockguard Pictures Needed - Fiberglass RV
Old 05-26-2008, 02:13 PM   #1
Booker B.'s Avatar
Hi,
After much searching I have decided to use my current Surfside rockguard that is on my Trillium. However, I would like to return it to the original condition. The current fiberglass panel is not mounted like the originals and I cannot figure out how they were mounted. My outside and bottom chanels are filled with chunks of plastic and I am not sure if this is what the originals are like.
I would appreciate it if someone could take some pictures of the backside of their Surfside so I can how the panels sat inside the frame and how they were attached.
Thanks in advance!
Old 05-26-2008, 09:02 PM   #2
Trailer: 1978 Surfside
Here are the pics of mine, I think this is what your looking for....hope this helps if not let me know.
Kent
kentj is offline   Reply With Quote
Old 05-27-2008, 06:42 AM   #3
Manitoba
Hi Booker B
I rebuilt mine. There was a single screw at the bottom of each side. Removal of same allowed the bottom horizontal piece to be rotated enought to slide out the fibreglass. The translucent wavey fibreglass has no mounting; it is only captured by the side channels and the bottom aluminum piece. Be sure you get both pieces oriented the same way, or you will be doing it twice. Check out: Surfside rockguard replacement
Old 05-27-2008, 09:49 AM   #4
Booker B.'s Avatar
Thanks!
Cam, where did you get your panels? I just stopped at Home Despot and all they have are PVC panels, no fiberglass ones.
Cheers,
Booker
Old 05-27-2008, 11:04 AM   #5
Booker B.'s Avatar
Whoops, just noticed you said Home Hardware in the other post. Thanks again!
Old 05-29-2008, 07:28 PM   #6
Posted on behalf of Vi Turner:
We have a 1979 Trillium 4500. the front rock guard was in terrible condition. We removed and disassembled the guard, took the center panel to a detail shop, had 'trillium' and the logo redone on the reverse side of the panel, then reversed the 2 side panels after scrubbing the weathered sides...the original 'trillium' and logo easily scrubbed off. Then reassembled the entire rock guard and reinstalled on the front window. The whole thing looks like it just came off the factory floor.
Old 07-27-2008, 07:28 PM   #7
Booker B.'s Avatar
Thanks all, the conclusion to this post is here:
http://www.fiberglassrv.com/board/in...howtopic=29337
surfside
Bigfoot rockguard pins Simon B Astin Problem Solving | Owners Helping Owners 13 06-20-2019 04:10 AM
1976 surfside fridge needed Michelle Blackett Problem Solving | Owners Helping Owners 8 10-10-2010 08:54 PM
Need a new rockguard ROIDON L Problem Solving | Owners Helping Owners 1 10-05-2009 11:06 PM
L'il Bigfoot Rockguard Michael Sinclair Problem Solving | Owners Helping Owners 5 03-14-2007 08:40 PM
SURFSIDE 14 TM help needed Legacy Posts Problem Solving | Owners Helping Owners 6 02-02-2003 11:23 AM
