Switch for running lights on BOLER 17' - Fiberglass RV
Old 09-25-2010, 02:37 PM   #1
KevinF's Avatar
Trailer: 1978 BOLER 1700 towed by 2001 GMC Jimmy SLT 4wd
New Brunswick
Question Switch for running lights on BOLER 17'
Just wondering if anyone has instructions on how I can switch my running lights on, on my 17' Boler, when the trailer is disconnected from the tow vehicle using the on board battery or converter?
KevinF is offline   Reply With Quote
Old 09-25-2010, 05:36 PM   #2
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
If you have a charging circuit from your TV then just use a wire jumper from that connector to the running light connector on the plug from the trailer.
Bill K
Old 09-25-2010, 06:29 PM   #3
Joe N's Avatar
Trailer: none
Wyoming
Just connecting the terminals at position 1 and 11 o clock on your umbilical cord will do it.
I suggest you use an automotive in-line fuse holder....otherwise, there won't be any fuse protection on the circuit.
(under "normal" circumstances, the lights are fuse-protected by the tow vehicles fuses.).
Joe N is offline   Reply With Quote
Old 09-25-2010, 09:31 PM   #4
KevinF's Avatar
New Brunswick
Thanks! Solution worked
Thanks to Bill, Joe and Brian. I tried the jumper on the plug and it worked fine. I really just wanted it to add to the festive look (of an already pretty festive look) of the trailer while parked on certain occasions. Don't think This trailer charges the battery from the converter so I don't think I'll be using this feature if I'm on battery power alone.
Old 09-26-2010, 06:10 AM   #5
Another thing you can do is put a two prong blinker for a car turn signal in the plug and the lights will blink.
Bill K
Old 09-26-2010, 12:42 PM   #6
Trailer: Fiber Stream
Post A commercially available unit, the flashCube
The flashCube does the same thing.
boler, lighting, lights
Running lights MountainHome Towing, Hitching, Axles and Running Gear 6 04-12-2008 11:22 PM
Trailer Running Lights Darwin Maring Problem Solving | Owners Helping Owners 0 12-25-2006 06:52 PM
Running Lights jrnutpaul Problem Solving | Owners Helping Owners 15 11-20-2006 08:57 PM
new running lights Dan Quinn Problem Solving | Owners Helping Owners 24 05-08-2006 06:06 PM
Running lights Carol Crawley Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
