T.V. , Low Voltage Ele. system - Page 2 - Fiberglass RV
Old 12-20-2015, 08:02 AM   #15
Trailer: 2016 13Ft Scamp
Thanks for All The Replies!
To see if the 13 ft Scamp tail light will work the way I want, made this tester.
EugeneFlorida is offline   Reply With Quote
Old 12-20-2015, 09:29 AM   #16
You are pprecisely correct it would be easier to get a plug and play light converter and plug it in.
You would then be limited the the lesser weight since the higher weights are predicated on the electronics detecting the trailer and stabilizing the entire system electronically. I believe if the Ford system is used and perhaps the GM well the on board sensors detect the yaw, roll, and accelerations etc and the car's CANBUS controls are compensated for towing. This has been required since 2005 in Europe along with checking those pesky trailer bulbs. This is the reason the tow limits are higher there and not the lower speed limits, smaller pounds etc.
The newer trucks are equipped with this technology and I think that Ford required for the higher towing limits that the package be factory installed and the computers adapted for it.
The computers and modules can, perhaps, be added after delivery, but you would have to ask Ford. I am familiar with the VW system and it can be added later and the computers programmed to function with the module and lights.
In the case of the VW (I don't know about the Ford or GM) the electric power steering will also give steering cues for the proper reaction to incipient trailer sway.
These systems are becoming very sophisticated today.
There are also trailer mounted stabilization systems available that brake individual wheels on the trailer as well. If you search for videos you can find several.
The easy way is not necessarily the best, but it is each individual's choice.
Bob, where you always advocating to follow the factory recommendations this is a major part of that now The lower limit is to be used without the proper electronic components and wiring. In the case of the Escape (I can't speak for the transit since it was not on my list of possible new tow vehicles) the limit is 2000 lbs without the factory setup (this means mostly the wiring kit and modules with the computer activation's as required whether factory or dealer) and 3500 with. Of course this would mean a brake controller as well. I don't know if the factory brake controller option ties in with the onboard computer, but it might as well.
Old 12-20-2015, 09:51 AM   #17
If the owners manual specifies a higher tow limit by adding additional components it's a valid hypothesis... But without that it's only conjecture.
Besides that, all the OP wanted was how to make his lights work, not a re-engineering discussion. And, as you said, you can't speak for the Transit.
Old 12-20-2015, 10:15 AM   #18
Many vehicles these days (including my Subaru) require a Blackbox/power module/ModuLite/power converter or what ever you wish to call them on the wiring harness at the point the harness connects into the vehicles wiring in order to work/play will with the vehicles built in wiring and features.
Old 12-20-2015, 11:20 AM   #19
Follow up
using two 1157 (regular bulbs and two LED light strips)
the test light board shows all light work. The only unknown to me ...
will the side markers light cause a Failure?
Well, I'll find out coming back from Backus in Late March
My TV is the Ford Transit Connect which is a mini Van (2000Lbs tow)
where the Ford Transit is a full size van.
FORD
Thanks again everyone
Old 12-20-2015, 11:31 AM   #20
Looks neat, is that with the Curt box, direct connection or what?
Old 12-20-2015, 11:38 AM   #21
Yes, Curt box
Low-Cost GPS System fusedlight General Chat 3 11-02-2012 03:29 PM
Low Voltage battery cut off???!!! dylanear Electrical | Charging, Systems, Solar and Generators 30 06-19-2012 09:47 PM
Can Low Voltage Fry the Breaker Switches? Adrian W Problem Solving | Owners Helping Owners 4 07-22-2008 11:55 AM
Low-Voltage Disconnect - Anyone Using One? dkdavies Electrical | Charging, Systems, Solar and Generators 6 10-06-2007 05:36 PM
Low Voltage Lighting Darrel Smith Modifications, Alterations and Updates 9 05-17-2007 11:23 PM
