Table and Hinge - Fiberglass RV
Old 07-05-2007, 08:23 PM   #1
Graeme's Avatar
Trailer: Boler 1300 1979
Hi all,
I have four "hinge marks" where I am guessing the table was attached to the Boler wall.
I believe, (but not positive) that it was a special hinge that allowed the table to move down to form the bed and up to make the table again?
If anyone had a picture, and knew where to get the hinge, or what it was called, or any info, I would be grateful.
My Boler project seems to be missing the table, hinge, and seats LOL and I would like to build it back up.
Thanks
Graeme
Graeme is offline   Reply With Quote
Old 07-08-2007, 04:08 AM   #2
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
Hi all,
Thanks
Graeme
Graeme, In my Boler Mfg. 1979 the table has a wierd type of hinge system that has just three anchor points on the Boler wall, though the lower one is a long, about 8 inchs.
The top two anchor points are used only when it is used as a table and these are just slots that hold the table tight against the wall.
On the table itself is the hinge device which is a "U" shaped swinging bar, the legs of the "U" attached to the table, that goes into this lower, longer hinge, and the bar will pivot in this wall hinge by swinging the table out and down or out and up.
I will take some Picts today and Post tomorrow and maybe this will help.
Gerry the canoebuilder
Old 07-08-2007, 07:13 AM   #3
Herb P's Avatar
Trailer: Boler 1700SGH (Stage II twoftitis)
It's basically what Gerry described; and I can also take pictures but I recommend not trying to replace the existing setup... It's used in all sorts of RV's so you should be able to pickup the pieces at an RV dealer... But the brackets are all soft mild steel and deform easily.. Once deformed, the table will wobble side to side, and if you lean on a corner, the other corner will pop out, etc... I made the mistake of reinstalling ours and using it once and I can confirm it's junk... My TODO list has an item to design a better bracket but sadly, I've not been able to come up with any good ideas... I had a similar problem in our old 1300 where the bracket is a long channel and a smaller but mating channel on the table...
It looks like Coast RV has those same 2 systems:
#40354 - the old 1300 style channel support.
#41388 - the style our 1700's use.
Doesn't look like the RV industry has "solved" this problem.
My only thought so far is to replace the single table leg with a collapsible leg from a community-hall type table... That doesn't address the bracket problem though.
PS: reading this thread I think Frederick has the right idea... Screw the brackets... When travelling, put the table in 'bed position' so you can put your coolers or what have you under it, then when you arrive, put the leg under the table, and you're good to go. Take it outside if you want to eat outside...
Herb P is offline   Reply With Quote
Old 07-08-2007, 10:05 AM   #4
Greg A's Avatar
Trailer: 2015 Escape 19
I just got rid of all that in my Scamp and replaced it with two of the aluminum stanchions.
Very inexpensive(less than $20 for two sets) and looks 1000 times better. Eliminates a ton of the wobble and easier to take up and down. The missus doesn't have to contend with all that hardware on the wall while sleeping now as well.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 07-08-2007, 02:48 PM   #5
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
My original Scamp one is in the loft above my shop..... Does that give you an idea of what I think of it?? Also, the old age "spread" of my Scamp precluded using the table as a bed base anyway--(fell thru!! ) Larry
Larry&Carrie is offline   Reply With Quote
Old 07-08-2007, 03:30 PM   #6
Greg A's Avatar
Larry,
We replaced the table with 3/4 Birch ply as well. (shown in pic)
The missus and I have roadtested the new table and can certify it's ability to be used as a bed base.
After hearing your story, I'm glad we didn't keep the original table.....
Hope you weren't hurt when you went through.
Owner:
Old 07-08-2007, 05:40 PM   #7
Herb P's Avatar
Attachment 8745
Yeah. That also looks like the ticket. I wonder about getting the flush mount post holes so you can still slide stuff under the table area while travelling. Cutting a circle in the floor isn't that big a deal I don't think.
The birch ply looks awesome btw. how did you finish the edges?
Old 07-08-2007, 06:25 PM   #8
Maine
[quote]
Hi all,
I miss spoke saying it had a long clip on the wall but 2 mounting points for the "U" bracket.
The 2 higher spots are for brackets that are mounted and can be seen on the table.
The table itself has a hinged leg in the front center, I should have taken picture but I didn't and the U bracket swings on the edge of table either in the up position or the down as in photo.
Gerry the canoebuilder.
Old 07-08-2007, 06:38 PM   #9
Victor Benz's Avatar
Hi:
I bought these brackets at Lee Valley:
http://www.leevalley.com/hardware/page.asp...,41319&ap=1
They are intended for 2" x 4" construction, but have many other applications, as you can see below.
http://good-times.webshots.com/photo/21792...052473095hrjhBL
http://good-times.webshots.com/photo/21874...052473095HCUKro
I installed them in the front wall and on the table, complete with a metal stanchion as shown below.
http://good-times.webshots.com/photo/26573...052473095EtwLtC
Under the paneling, the front has half inch plywood support frame, fibreglassed in and screwed from the outside.
http://good-times.webshots.com/photo/24859...052473095gtXuMK
http://good-times.webshots.com/photo/24854...052473095WxuInl
Victor Benz is offline   Reply With Quote
Old 07-08-2007, 06:59 PM   #10
Talking
Larry,
Greg- - - naaw - it was on her side (I sleep against the back wall) Bur, Carrie came thru unscathed Larry
Old 07-08-2007, 07:23 PM   #11
The one in my Scamp is identical to the picture Gerry provided. And I like it. It's easy to use. I prefer having as much of the floor under the table available for my feet. Have you ever been in a restaurant booth where you fought for floor space for your feet? Tables with multiple legs and those upturned "bowls" for leg supports remind me of that problem. It's easier to slide stuff under the table too, if there's nothing in the way. When my table is down, in bed mode, the table leg is already out of the way (hinged up under the table) which leaves the entire floor area under the table for sliding totes, etc. out of the way.
Old 07-08-2007, 08:51 PM   #12
Herb P's Avatar
Hey Victor; that looks great...
Did you build the 'butcher block' table or buy that somewhere too?
Old 07-09-2007, 07:13 PM   #13
Graeme's Avatar
Can't thanks you guys (girls) enough for your pictures and posts. It has defiantly made me not want to re-do the old hinge.
Taking the time to post and take pictures is a great motivator and truly appreciated. I only have 999 more questions to go.....
I like the double table leg idea, it looks great, only issue is I am 6'3, 230 lol and leg room is always a problem. ( I don't really fit on the bed either, the family can stay in the Boler I bought a tent
I think that I might have to stop at Lee Valley in Ottawa and check out the hinges. Besides I get an excuse to wander around the store....
I will post some updated pictures, I am just about ready to paint, then start laying the new floor.
I am amazed at how fast I became a Boler addict.... Thank Goodness I found a support group lol
Graeme
Old 07-09-2007, 09:48 PM   #14
Greg A's Avatar
Wow, Graeme you will probably need to eat outside as well.
On my table I made angle cuts on the end to allow more room to slide in and out of the dinette seats, but don't know that it would help at 6'3.
Thanks Herb, birch ply is a simple 45degree cut and then heavy sanding. All the new cabinets in the trailer match the table.
Donna-surprisingly there is more legroom under the table then with the original setup with all those metal things coming out of the wall. Shocked me too. Doesn't cause an issue with putting stuff underneath when it's down at least for us. Actually acts as a separation for his junk, her junk at night....
Larry- glad to hear Carrie survived the break thru.
Victor- I like those brackets you found... Awesome table setup.
Owner:
Old 07-10-2007, 01:07 AM   #15
peterh's Avatar
I was thinking the same way, but on our Scamp 5er the gray water tank is directly under the dinette, so unless I'm looking for direct drainage from the dinette . . .
--Peter
Old 07-12-2007, 12:36 PM   #16
Trailer: 1979 Boler 1300 Honey
We have a 79 Boler and the table is supported by only one aluminum stanchion and it has served us well for the past 20 years. Underneath storage has never been a problem. Can't send any pictures as it's gutted inside for redoing.
Hi all,
Thanks
Graeme
Diana Dixon is offline   Reply With Quote
Door hinge options kentj Problem Solving | Owners Helping Owners 10 04-06-2015 02:34 PM
Door hinge Spacers Legacy Posts Problem Solving | Owners Helping Owners 0 07-11-2003 07:45 PM
Replacement door hinge Legacy Posts Problem Solving | Owners Helping Owners 7 05-27-2003 04:22 PM
hinge help Legacy Posts Problem Solving | Owners Helping Owners 2 04-12-2003 06:37 PM
» Trailer Showcase
P-eggy
itlives
Dorny
sam mc
