Table modification ideas! - Fiberglass RV
Old 03-29-2015, 09:09 PM   #1
Trailer: 1975 Trillium 1300
So I have a '75 trillium 1300. The boyfriend and I are, let's just say, not small people. We are finding it a bit of a squeeze getting in and out of the Dinette benches. Has anyone moded the table to allow better access to the benches without compromising the stability and size of the bed when the dinette is turned down?
Lilly The Trilly - 1975 Trillium 1300
PrettylilTrilly is offline   Reply With Quote
Old 03-29-2015, 11:14 PM   #2
David B.'s Avatar
If you look at the mods I did to our 13' Scamp, I think you could do the same to your Trillium. Scamp still sells the hardware. I replaced our factory table top with a custom built two piece unit that was hinged. It was supported by drawer slides when extended. The small table version made it very easy to sit behind or next to, yet allowed one to extend the table to full length while seated. Click on our avatar and go to our albums to see all the pictures.
Dave & Paula
Old 03-30-2015, 10:11 AM   #3
Raz
Raz's Avatar
One member modified their table with tracks underneath so it would slide back and forth.
I wanted the floor space for the dog at night, so I made a pedestal for ours. This makes it easy to slide back and forth. Unfortunately, because of the shape of the wall, the original front table doesn't work well. We made the rear a permanent bed so I took that table and cut it down. Raz
Old 03-30-2015, 10:27 AM   #4
David Tilston's Avatar
On Trillium 4500's, they have a leaf in the table. When it is removed, it is much easier to sit down.
Old 03-30-2015, 06:47 PM   #5
Roger C H's Avatar
We only use our front table. The rear 'table' is a sheet of plywood made permanently into a bed. Under the front table, we have drawer slides that allow sliding the table to either side which makes it easier to access the LH side which is next to the sink.
Old 03-31-2015, 08:44 PM   #6
Dave & Paula
Thanks for all the ideas! I especially like the idea of a hinged table. However may make the hinged section a bit smaller
Shower Modification Bigfoot 25B25RQ Bigfoot Mike Modifications, Alterations and Updates 18 05-29-2009 10:38 PM
ideas for hinged table leaf theresa p Problem Solving | Owners Helping Owners 0 02-10-2009 02:21 PM
u dinette modification *photos* Flygal Modifications, Alterations and Updates 10 11-05-2008 12:12 PM
24v and 12v AirConditioners for your next Modification Coach George Jessup Modifications, Alterations and Updates 17 07-27-2008 09:38 AM
Bigfoot B17 Bed Modification Maureen M. Modifications, Alterations and Updates 3 08-30-2007 04:00 PM
» Trailer Showcase
La Palapa
Paula
TBD
Andi
