Table wont stay up on hinge - Fiberglass RV
Old 09-01-2015, 09:12 PM   #1
Manitoba
Hi
I am working on multiple levels of the boler, and am trying to solve the table problem Im having. The original metal hinge thing does not sit proper anymore...and the table keeps slipping off it when in table mode. Does anyone know of a better way to rebuild the table to stay in the table position? Some kind of long quick release hinge? I don't know...I'm reaching.
Thanks
dhwilder is offline   Reply With Quote
Old 09-01-2015, 10:21 PM   #2
Originally Posted by dhwilder View Post
Hi
Thanks
Buy new hardware from Scamp.
Dose this look like what you need.
Old 09-02-2015, 04:34 AM   #3
james kent's Avatar
Trailer: Boler 1984
Hi
Thanks
If your Boler has the track and not the hinge connection type try holding the table up at a 45 degree angle when attaching. That seems to make it fit into the groove of the track better.
Old 09-02-2015, 09:16 AM   #4
Manitoba
That looks interesting...not what i have but I wonder if it would work?
Old 09-02-2015, 09:37 AM   #5
Manitoba
My trailer does have the track but it just does not want to grab on anymore. Is that hinge system difficult to put on a table that had the track system?
Old 09-02-2015, 09:24 PM   #6
Gilda's Avatar
Trailer: 2011 Scamp 13'
I have no experience in replacing or repairing the table but some campers have a pedestal table. The base flange attaches to the floor, a metal cylinder fits into the floor flange and the flange on the bottom of the table fits onto the cylinder. Pedestal Table Leg 29-1/2 w/o Base - $9.99
The Gleeful Glamper
Gilda (Jill-da)
Old 09-03-2015, 04:28 AM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
You can also purchase replacement parts like what you describe. AP Products Table Support - Supports & Brackets - Table - Hardware
But if the one you have has been bent, it may not hold well. Have you tried taking it off the wall and straightening everything?
Old 09-03-2015, 06:42 AM   #8
John Linck's Avatar
Madison, Wisconsin
I have had to rebend my table's wall atachment hardware after getting it hooked too low thru my error. After some work with a hammer on my bench its all better now, snug and wiggle free. I'm more careful now when I hook it up when raising the table.
Too soon old, too late smart.
John
John Linck is offline   Reply With Quote
Old 09-03-2015, 11:07 AM   #9
Manitoba
I will try that
Old 09-03-2015, 03:40 PM   #10
Manitoba
I will try that
SO that bracket was perfect...only problem...they dont ship to Canada!!
Doh
Anyone know of a similar product available in Canada?
Old 09-03-2015, 03:50 PM   #11
Trailer: 1979 Scamp 13'
I believe this is the same thing:
http://www.amazon.com/Products-013-1.../dp/B00G44IZEO
Zennifer is offline   Reply With Quote
Old 09-03-2015, 04:16 PM   #12
Raz
Raz's Avatar
Vermont
David, I used one of those brackets to make a bed extension. Try loosening the screws. If it works, you need to add shims. What I found is that both pieces need to be parallel or they won't interlock. Put a strait edge, (a yard stick is what I used) against each piece and look for gaps. Shim as needed. Raz
Old 09-03-2015, 10:13 PM   #13
Manitoba
David, I used one of those brackets to make a bed extension. Try loosening the screws. If it works, you need to add shims. What I found is that both pieces need to be parallel or they won't interlock. Put a straiot edge, (a yard stick is what I used) against each piece and look for gaps. Shim as needed. Raz
I bought the one on amazon...
boler
Boler Bargman L-400 handle wont catch spring shan.mcc Problem Solving | Owners Helping Owners 0 05-26-2012 09:30 AM
door lock (it wont!) cyndi H Problem Solving | Owners Helping Owners 5 06-22-2009 01:23 PM
back button wont work Rick kl Forum Admin, News & Announcements 2 10-26-2008 04:55 PM
Table and Hinge Graeme Problem Solving | Owners Helping Owners 15 07-12-2007 12:36 PM
back button wont work Sue S Forum Admin, News & Announcements 0 01-01-1970 12:00 AM
» Trailer Showcase
William
Liessi
Scamper
Rodney
