tail light issue - Fiberglass RV
Old 06-29-2012, 11:12 AM   #1
Trailer: boler
tail light issue
Hi, everyone
I have 1974 13ft Boler, it has problem for right side tail light.
it works for night driving, but it does not turn on when flashing signal.
i guess I have to go anywhere no right turn for a while if I can not fix it..
could someone give an idea where I need to look at first?? thanks
invermian is offline   Reply With Quote
Old 06-29-2012, 11:31 AM   #2
Roy in TO's Avatar
1st check the bulb and socket, then check your wiring plug on your tow vehicle with a "trailer harness tester". The harness plug tester will give you an idea if the problem is in the wiring of your vehicle or your trailer.
Old 07-01-2012, 11:27 PM   #3
Trailer: boler
thanks, I will try tester, then think about next.
Old 07-02-2012, 07:26 AM   #4
Dudley's Avatar
Trailer: 1998 Casita 17 SD
"divide and conquer " If the tow vehicle tests out my guess is a bad ground in the light assembly. I would check for corrosion and clean the bulb or replace it. The park lights may be turning on dim as they may be getting ground from the left side bulb. On my Ventura the ground wire was just wedged behind the metal plate that the bulb sockets were mounted, 36 yrs of oxidation caused them to fail. I have since drilled a hole and used a self tapping screw to attach the wire.
boler, light
Tail light help..... Randy Bishop Problem Solving | Owners Helping Owners 13 08-31-2011 08:09 PM
Need tail light help Vicki A. Problem Solving | Owners Helping Owners 5 03-06-2010 10:18 AM
Tail light replacement Wayne Dirkson Problem Solving | Owners Helping Owners 5 06-15-2009 07:43 AM
Tail light issue on Surfside Shelley Problem Solving | Owners Helping Owners 6 07-16-2008 09:08 PM
need tail light Legacy Posts Problem Solving | Owners Helping Owners 8 04-12-2003 07:36 AM
