Tail light lenses c10 u haul - Page 3 - Fiberglass RV
Old 08-07-2011, 07:34 PM   #29
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Even in the $100 range, we would be interested. (I'm CindyL's husband.) Our set is getting so brittle that they crack a bit more every time I have to take them off to clean or change/fiddle with a bulb. Also, they are becoming less transparent each year. We have LED lights in the housings, but they still aren't very bright because of the discoloration/scratches over the years.
The small marker lights mentioned by CindyL only cost a few dollars ($2.10 for the light assembly with cover and $.75 for just the plastic cover), but they don't say UHaul. I think her point was to get a cast made of the originals so that the replacements would still say UHaul.
Old 08-07-2011, 07:41 PM   #30
CindyL's Avatar
Illinois
And speaking for myself, how much over the top expensive would a two-tone housing replacement cost?
CindyL
CindyL is offline   Reply With Quote
Old 08-08-2011, 08:42 AM   #31
Trailer: Wally Byam Holiday
costs
Hey
let me get the first ones done and see how it goes. The problem of the two color starts with the fact I would have to split apart the existing lens into two pieces.Clean and polish each piece, then make a mold of each cast a prototype, retool that then make molds of each prototype then cast each separately, one in amber then one in red. Then reassemble the two halves. It's a doable thing but I told my friend I was not willing to try to take the amber and red apart for fear of breaking them. He told me they were impossible to come by. I was pretty sure I could take the two halves apart without damaging them but just didn't want to take the chance I might break them.
I can't make replacement lenses with UHaul on them IF UHaul is making them. It's a copyright issue. I'm on the edge with making the dupes of the ones for my friend. Since UHaul isn't making them I'm not in competition or taking any money out of thier pocket so to speak. To be on the safe side I should probably rewmove UHaul from the ones I'm making but since they are no longer making them I don't think they would care. Famous last words.
lanny
LWEBB is offline   Reply With Quote
Old 08-08-2011, 09:35 AM   #32
Trailer: 1984 UHaul CT13
Smile
Originally Posted by LWEBB View Post
Hey
lanny
Lanny,
The hundred dollar range would be ok for me too. I'll follow your progress.
Patti
keekers is offline   Reply With Quote
Old 09-15-2011, 12:02 AM   #33
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Larry, I am interested also for my U-Haul CT-13.
I have already purchased the U-Haul 4" round conversions but have not installed them as I would really like to keep the original lights if possible.
The housings are in remarkably good shape with no socket corrosion and the lens have been replaced with a flexible plastic that has red lens repair
tape on the inside. They work but definitely need replacing. You can contact me at djtriceflt@comcast.net if you are able to produce them. Thanks and Good Luck! don
djtriceflt is offline   Reply With Quote
Old 09-15-2011, 04:38 AM   #34
Trailer: 85 U-Haul CT
Ohio
Lanny,
Count me in for a set too. I have the metal adapter housing, but don't want to use them unless it is a last resort. Takes too much away from the UHaul design. I'm sure many people will be interested in your repros.
Marty d
Marty D is offline   Reply With Quote
Old 09-15-2011, 06:03 PM   #35
I hope Lanny didn't scared off with all the clamoring for lenses
Last Activity: 08-08-2011 08:30 AM
Come back Lanny!!
Old 09-16-2011, 04:26 AM   #36
Ohio
Come back Lanny!!
When something new comes along for the UHaul, it's like the finding of the Holy Grail ! I hope Lanny can make a go of doing the lens. I think the 100$ a set sounds reasonable when you have cracked lenses. And I would really would hate to use the metal adapters that I bought for "just in case". Now if I can find someone to make the rubber gaskets to fit, and install everything for me, I would have it made.
Marty D
Old 09-29-2011, 12:32 PM   #37
Don't give up on me on this. It's been a real character builder not to mention a black hole for materials.
As it turns out, while the mold would barely fit into the pressure pot, it didn't really fit the mold would warp slightly when the door was screwed down yielding a really messed up casting.
I built an oven of sorts with heat lamps and a heating pad as a base hoping the polymer casts would cure but they never did.
So the red lens was a bust. My solid casting materials, however, will set without heat or pressure so I cast a replica in solid polymer and retooled it. I modified a jewelers saw so I could cut the top from the bottom halves apart. Each piece then had to be tooled again slightly. I then made two separate molds one for each half.
The molds are still large but I Think! I can set the pot to hold each half with a little gerry rigging. If that's the case, I'll mold an amber side and them a red side then I have to build a jig to hold the two pieces together while the epoxy glue dries.
Doesn't sound all that complicated when I write it but it's been a real project.
The two part molds look good so I'm hopeful. End result, if it works will be the two colored lens vs the solid red.
I'm headed out of town again so it will be a week before I can get back on it. I have several other standing orders for other lenses and for a Bargman tail light fixture I need to get out of the way first but I'm working on it!!. I'll let you know. Wish me luck.
lanny
Old 09-29-2011, 01:04 PM   #38
djtriceflt's Avatar
Thumbs up NOT giving up Lanny!
Thanks for your persistance. My/our hope is that you will be persistant and
be successful on this as I know many of us would sure like some
replacement lenses! I recently discovered my left rubber housing was badly cracked and I am attempting to repair it with 3M black adhesive silicone gasket maker. With amber lenses , I believe a tail light converter may be the answer to go from a 2 way to the 3 way that the UHaul requires for separate amber turn circuit not combined with the brake signal. I am in the process of trying that as I would like to have the amber lights working again as turn signals only, and if anyone knows about that I would sure appreciate the info. Good Luck Lanny and let us know!
don near the Keys in S. Florida
lanny
Old 10-01-2011, 08:56 PM   #39
Pam Garlow's Avatar
Trailer: U-Haul 1985
Here's another CT owner that is 'looking ahead' to needing new taillight lenses in the future. You have a line forming, Lanny And if you want to post photos of your progress and the process used to make the lenses, it would be fascinating to see!!
Old 11-16-2011, 03:22 PM   #40
Hey All, I haven't abandoned the project just had a lot of other stuff on my plate. My new web site is customvintagetrailerparts.com
Back to the issue at hand:
an update.
I have had a little time this week to get back to the lens.
I'm not thrilled with the result but I plan on giving it one more try in a couple weeks. There are a number of surface irregularities on the front and several places on the back which don't show here that are not shiny and you can see them from the front.
The glue I used isn't going to work so I will try another approach. It was just too messy and hard to control. I made a brace to hold the two pieces together but it's a #X1x to get it right.
Anyway just to let you know where it stands. I'll have more time come December. I'll either get it to work or know then if I can't. At this point I'm sure it will not meet my standards but it may be a reasonable option for some of you.
Lanny
Happy Thanksgiving!
Old 11-16-2011, 03:24 PM   #41
Sorry I posted two of the same shot. Here's another one.
Old 11-16-2011, 04:46 PM   #42
CindyL's Avatar
Illinois
OK, if you compare the ones you made with the ones on my '87 Uhaul, mine lose! These look very good!
CindyL
light
tail lights c10 u haul bobby goddard Classified Archives 6 07-04-2011 10:28 AM
eBay Boler tail light lenses Gina D. Classified Archives 0 11-02-2008 07:20 PM
Tail light lenses for Compact II left side thomast Classified Archives 1 09-05-2006 03:27 PM
WANTED: tail light lenses wayne s Classified Archives 1 07-26-2006 03:15 PM
u haul - tail light cover Tom Stewart Classified Archives 4 04-18-2006 09:49 AM
