Tail Light Wiring - Fiberglass RV
Old 04-16-2012, 01:08 PM   #1
Trailer: U-Haul CT13
Tail Light Wiring
I'm going to remove the converter thing in my U-Haul and have seperate Tail Lights and running lights and stand alone 120v power.
I'd like to replace the marker lights with LED's but it seems that most LED marker lights only have one wire. I assume they use the frame for grounding. Obviously that won't work with the fiberglass body.
Any ideas on grounding the lights?
Jim
Sundance is offline   Reply With Quote
Old 04-16-2012, 01:13 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
UHaul used a single wire light for clearance lights and soldered a ground to the mounting rivet plate.
Old 04-16-2012, 02:08 PM   #3
If you R replacing the lights then the ones that R already there will have the 2 connections you will need. Test your LEDs B 4 you install to discover where the return wire connects 2 it.
light
Tail light help..... Randy Bishop Problem Solving | Owners Helping Owners 13 08-31-2011 08:09 PM
Pig tail wiring question DannyH Problem Solving | Owners Helping Owners 9 11-25-2010 04:06 PM
Need tail light help Vicki A. Problem Solving | Owners Helping Owners 5 03-06-2010 09:18 AM
Wiring Scamp tail lights Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 06-01-2003 08:50 PM
need tail light Legacy Posts Problem Solving | Owners Helping Owners 8 04-12-2003 07:36 AM
