Tail Lights - Fiberglass RV
Old 06-25-2016, 10:10 AM   #1
Trailer: U Haul CT 13 - 1984
Ohio
Tail Lights
Hello All,
The rear lights on my CT13 has a place for two bulbs. One in the amber lens and the other in the red lens. Only the bulb in the red lens works. Has anyone figured out how to make the turn signals work in the amber lens, and the brake lights work in the red lens?
Coleslaw is offline   Reply With Quote
Old 06-25-2016, 10:54 AM   #2
It will require extra wiring. If your tow vehicle has separate rear turn signals, not using the same wire as the stop lights, you'll have to tap into those wires. Note that the amber section of the lens uses a two filament bulb, but only one wire of that bulb socket is used. There may be a wiring converter available to do what you want, check on etrailer to see if there is.
Old 06-25-2016, 12:15 PM   #3
Ohio
Amber Lights
Mary and Bob,
This makes perfect sense. Although, what was the amber light for in the first place? Does yours light up for anything? Ours do not light for turns, brakes, or anything.
Thanks,
The Coleslaw's
Old 06-25-2016, 12:55 PM   #4
The amber was originally used for turn lights with Uhauls odd way of wiring. I installed all new light wiring because the original was deteriorating. I only use the red part of the lens. I also mounted a marker / stop / turn light bar above the rear window for extra visibility
Old 06-27-2016, 06:45 AM   #5
Joe MacDonald's Avatar
if you really want the amber to work, you can get a converter that will separate out the turn signal from the brake light and marker light, it can be installed somewhere near the rear of the trailer. it does the opposite of the ones most people buy if their tug has orange signals/red brakes
Joe
light, lights, tail lights
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
eBay Tail Lights Frederick L. Simson Classified Archives 0 01-22-2006 09:42 PM
Tail lights Legacy Posts Problem Solving | Owners Helping Owners 32 07-27-2003 09:29 AM
Wiring Scamp tail lights Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 06-01-2003 08:50 PM
