It will require extra wiring. If your tow vehicle has separate rear turn signals, not using the same wire as the stop
lights, you'll have to tap into those wires. Note that the amber section of the lens uses a two filament bulb, but only one wire of that bulb socket is used. There may be a wiring converter available to do what you want, check on etrailer to see if there is.
