What kind of tape can I use on the outside of my trailer that will hold, keep water out, but not create a sticky mess of glue to remove later? I need to tape a garbage bag over my window to keep the water out until I get into my repair shop.
You could use painters masking tape for a short term fix, I'd just use duct tape. Acetone (also in nail polish remover) works fine to remove residue easily if need be.
Charlie Y
When we had leaks we used 3 M duct tape until we could troubleshoot the leaks. It was on for several weeks and left very little residue. One member used some cheap duct tape and had real residue issues so buy the good stuff. Good luck, Raz
Don't use generic, cheap DUCT tape... no, no, no... the glue turns to concrete! If the gelcoat is dry, even the clear, packing tape works okay. But don't leave anything on for days on end... especially in the heat.
Don't ask me how I know.
