Television options - Fiberglass RV
Old 08-31-2016, 07:40 PM   #1
Trailer: Casita Spirit Deluxe 17'
Television options
Our 2006 Casita came to us cable and antennae ready but it came with no TV. I doubt we will be watching TV much but would like some recommendations on what people are using. TV's, laptops, IPads?
SuzieDavis is offline   Reply With Quote
Old 08-31-2016, 08:18 PM   #2
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
We have a 19-inch Toshiba LED TV.
Old 08-31-2016, 08:36 PM   #3
Do you use your Casita antennae or did you purchase a different one? I heard the factory cable and antennae hookups aren't as good as other antennaes. Thx for responding!
Old 08-31-2016, 10:06 PM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
Did yours come with an antenna? My 2006 came with a Winegard that wasn't really very good. Several owners have installed the King Jack antenna (which I have on my Escape) and been very pleased with the performance. I even installed one at home!
I like to have local news wherever we are, particularly for the local weather.
We use the built-in DVD player on the road fairly often, plus stream Netflix now and then using our cell phone for the internet connection.
Charlie Y
Old 08-31-2016, 11:50 PM   #5
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
In the long run it is not so much about what other people do as it is about what your needs are for power and for the type of connection you want to use to access your entertainment. Once you know that then you can sort out what options will give you the best display to fit within those parameters.
Old 09-01-2016, 05:46 AM   #6
Trailer: 1999 Casita 17' SD
Ohio
I made a metal bracket and hung a 13" LED TV in the corner.
We don't use it much because where we go there's seldom any reception.
We have the original "Bat Wing" antenna that was installed on the older Casita, ours is a 1999.The Bat wing works fine in our driveway and picks up many local channels.
Joe
Old 09-01-2016, 07:33 AM   #7
Thanks for the great comments and suggestions!
Old 09-01-2016, 07:44 AM   #8
I bought an Insignia 24" at Best Buys relatively cheaply.
It has a 12 volt power supply (from 120 vac) ao I believe that it will also work off 12 volts if i wanted to use it that way.
It also has a DVD player built in.
I mounted it on a heavy duty swing out mount so we could adjust it for viewing.
I mounted ours on the refrigerator/microwave closet wall since we have twin beds in our 16' Scamp (much modified).
We have one of those flat "HD" antennas that works good sometimes and sometimes not.
In our full-time 5th wheel I installed the King Jack to replace the Wineguard and it works great! I may put one on the Scamp, but so far it has not been a priority for us.
We are getting ready to retire in the next 18 months sometime and the Scamp is for that time.
Old 09-01-2016, 02:12 PM   #9
Connecticut
Antenna & TV Options
Hey Suzie,
I have a Spirit Deluxe with the factory antenna, I would say the performance is marginal at best. I am having a Jack antenna installed and have heard many positive comments about them. Larry Gamble from Little House of Customs is doing the install and it's easier and less expensive if you already have the factory antenna. I have a 19 inch TV/DVD combo from Axess which is also AC/DC. I am very satisfied with the performance overall, sound quality could be a little better or maybe my hearing could. Hope that helps. Peace!
wwig is offline   Reply With Quote
Old 09-01-2016, 02:36 PM   #10
Great info! Thx so much!
Old 09-02-2016, 01:06 PM   #11
Trailer: 2013 Escape 19
+1 TV + DVD Player. While camping at a National Park this summer, we enjoyed watching the PBS National Park DVD series each evening. Figure a 19 to 20 inch TV+/-. Also decide where you will be sitting while watching TV which will help you decide where to mount it. Also consider proximity to power.
Old 09-02-2016, 01:08 PM   #12
Thank you!
Old 09-02-2016, 09:28 PM   #13
Dan Meyer's Avatar
If I wanted TV in my Scamp, would get a USB-TV tuner for my laptop, and an external speaker.
--Dan Meyer
Old 09-02-2016, 10:35 PM   #14
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
We opted for a small flat screen and mounted it like this.
starting at post 149.
There's a hole in my Boler my Boler my Boler
FRED SMAILES is offline   Reply With Quote
Television Needed Bruce Thomas Care and Feeding of Molded Fiberglass Trailers 33 02-17-2012 03:18 PM
Cabinet Liners and Television Mount? stephanie reed Problem Solving | Owners Helping Owners 13 05-24-2011 03:19 PM
Options, Options Options Tezha Problem Solving | Owners Helping Owners 8 09-19-2010 11:55 AM
television cable Legacy Posts Modifications, Alterations and Updates 6 03-31-2003 12:32 AM
television needed Jayson Jones Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
