Television questions - Page 2 - Fiberglass RV
Old 02-09-2014, 03:46 PM   #15
jgraps1958's Avatar
Trailer: 2013 Scamp 16' 2012 Jeep Wrangler JK 4 Door
Lancaster County Pa
Carol, I know I saw pictures of your TV and mount but I can't find them now. Can you please re-direct me and tell me where I can buy that mount. Thanks.
jgraps1958 is offline   Reply With Quote
Old 02-09-2014, 05:23 PM   #16
Trailer: Casita 17 ft DLX SD
Factory Antenna
Originally Posted by jgraps1958 View Post
Thanks Carol, I wrote an e-mail to Scamp to try to get more info since I found nothing in my paperwork. I will assume it is basic and cheap. I ordered an outdoor antenna from Tvantennasale.com. I'm sure the factory installed antenna will not have a range of 150 miles like this one does. I'm trying to cover all bases. Thanks for your help.
I had the factory TV antenna on my 1999 Scamp and I have the factory amplified TV antenna on my 2013 Casita. I found both antennas to have a relatively short range and provide marginal performance at best . My Casita TV works just great when hooked to a cable or satellite TV signal.
Old 02-09-2014, 06:39 PM   #17
The thread for TV mounts which has some pictures of the one I put in is at Television Mount. There is also a photo on my trailer register - link under my name on the side bar, Happy with it as it very easy to take the TV down while traveling and stick under bedding - I use push on type connections for the rear cables so easy to put back up. Its a PDR Under Cabinet Mount with Quick Release.
Old 02-10-2014, 06:37 AM   #18
jgraps1958's Avatar
Lancaster County Pa
Thanks Steve, that's what I thought they would be.Glad I have a back up plan in the works. If that works half as good as they say I'll be happy.
Carol, Thanks again, I knew I saw it somewhere and liked it ! It looks like a great set up. I feel it is important to put the TV down when traveling to limit damage.
Old 03-04-2014, 06:21 PM   #19
Trailer: 2011 Scamp 19 ft Deluxe
OK Jon, your link to the antenna store was helpful. My main question is when you buy the basic boom a rang antenna from Scamp for 40 bucks I think all you get is an antenna and a hook up port inside the camper, am I correct in this thought ???? It's rang may also be very limited, right ??
My Scamp installed "boom-a-rang" antenna came with a booster. Part of the Scamp antenna package. Look in a cabinet close to where the cable from the antenna enters the cabin. It gets it's power from the 12 volt side of you electric.
Jeffrey S. is offline   Reply With Quote
Television Needed Bruce Thomas Care and Feeding of Molded Fiberglass Trailers 33 02-17-2012 03:18 PM
Television mount cpaharley2008 Modifications, Alterations and Updates 34 10-13-2011 02:09 PM
Cabinet Liners and Television Mount? stephanie reed Problem Solving | Owners Helping Owners 13 05-24-2011 03:19 PM
television cable Legacy Posts Modifications, Alterations and Updates 6 03-31-2003 12:32 AM
television needed Jayson Jones Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
